Toshiba 52hmx84 52"" Diagonal Cinema Series Hd Monitor Dlp Projection Logo
J
Jesus Armando Nevarez Posted on Jan 12, 2015
Why does my tv not play my cd player or video game console. the sounds comes on but no video.
Paul Roberth Ernst
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Jan 12, 2015
Paul Roberth Ernst
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
3049
Points
38
You need to upgrade your tv with DirectX....
Xbox works fine but wont show up on the tv, sound is coming out but no video.
For, first time u should the following
play a movie using the Media Player for Xbox 360, a Windows firewall warning will appear
Note: This is due to the Xbox 360 playing the movies over the network.
Simply click the "Unblock" button on the window that appears (see below) and the
movie will play fine, i think so. You only have to cancel this warning once.
It says play dvd,when new game is in
check first if the cd game will play in other game consoles.
Probably its in the game cd.
White lines on the TV
sounds like the video processor has died
It will be cheaper just to buy a relacment console
if you can't find one locally then try ebay
http://shop.ebay.co.uk/items/?_nkw=megadrive+console+only&_fromfsb=&_trksid=m270
also you may wisdh to consider a RGB lead for better quallity video picture
http://www.retro-cache.com/
4answers
Connecting to a video game console
Hooking your PS2 Up To your Stereo
Just got a PS2 and trying to hook it up to your TV, stereo or both? Here are instructions to help you get everything working smoothly.
First, some basic cable definitions. These are pretty much standard for ANY system or stereo you ever get, so it's good to learn them.
RED CABLE - right channel for stereo sound (get it - Red Right?)
WHITE CABLE - left channel for stereo sound
YELLOW CABLE - video signal
Your PS2 plays games and plays DVDs. So it is generating signals that go OUT of that box. You want those signals to go IN to your TV. The most simple way to do this is to simply plug them into your TV, if you have no stereo system hooked up and nothing else attached to your TV. Most TVs have stereo left in, stereo right in, and video in. Most in fact have them all color coded with the above colors. So all you do is plug the cables in and turn the TV on. Some TVs have to be set to channel 2 or 3 to know to take the signal in from the Video In line, but your manual would tell you if that was the case. Here is a diagram of the straight connection.
I would really recommend hooking a stereo system into your TV, though. The PS2 has INCREDIBLY stereo sound and you really miss out on a lot if you just have the sound coming out of your TV speakers!! Especially if you play DVDs through your PS2, you want that sound coming out of the stereo system. So in this case you would send the video to your TV, so your TV can show the picture. You then send your audio (sound) to the stereo, so it can play the sound. Most stereo systems have multiple input spots so you can plug in your CD player, your tape player, your record player, etc. So just choose an input spot that isn't taken yet. Here's an image of that connection -
So let's say you don't have a tape player and therefore plug the red cable into "Tape Input R" and plug the white cable into "Tape Input L". To make the sound play, you would now press the "Tape" selection button on your stereo so it played the music coming through the tape channel. Since that's where your PS2 is plugged in, that is the sound that will come out of your speakers.
No music from player #1 port
i have noticed that playing two player with the sound too.. my disk was dirty too.clean it first.. Second if your just playing through your T.V. well its prob mono.. or if your playing through a home audio/video check your audio rca's make sure there pluged in all the way. if you are using home stereo newer model you can use the fiber optic on your ps2 the sound is better make sure your stereo has the same thing or it would be a wasted trip to the store.
CD SOUND QUALITY ON PS3
r video and audio set to HDMI
or try playing with the audio settings the ps3 might not be set to play the audio format
2helpful
3answers
How to connect two ps2 for playing 1 to 8 player games
yes there is away , but you need 2 Tv's and 2 playstation 2 consoles , and you use what is called link up, try to imagine 8 different screens on one TV , be alittle small , lol
hope this helps
2answers
Console
It may be that the laser is aligning itself after trying to run the disc, you may need to run a cd cleaning and aligning disc in the playstation, although, it maybe that the laser is on it's way out.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
