I ordered it of Argos i have contacted them as well as un sure if the microwave is working like it should,there is no beeping at the end of a program and its meant to be?a red light that is permanently on,excepted when using it?like to know as will need to return it if it's not working right?
SOURCE: intruction manual needed
Since the company seems to not even offer microwave ovens currently which, to me, is an indication that they are buying and having rebranded some Asian (Chinese or Korean) make and may not even have service information or support.
I checked a site you may not have found that often has info available, Retrevo.
You might want to visit and bookmark it in case they acquire what you need in the future;
http://www.retrevo.com
SOURCE: Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: Delonghi AC930AMQ Microwave, Interior Light Bulb
Managed to figure out what the problem was ,I was a bit heavy handed with the solder/flux which caused a short cleaned up the area around the solder joints and now working great
SOURCE: AC925EQK microwave. flashing light, not heating up
Mag tube Shot
Testimonial: "thanks very much"
SOURCE: my delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
