I have not tried anything
SOURCE: Spin Cycle/Machine makes noise and moves
You can't tight up the tub. You should replace the damper pads that located beneath main support housing on base's machine. Goog luck !
SOURCE: excessiv drum movement back and forth
this noise is from the drum bearings and yes its a big and exspensive job to do complete strip down and will more then likely cost around £120-£160 to do if u like the washer and its in good condition then have it done because zanussi's and r good machines u can buy the rear of the drum with the bearing already in it but it still needs the drum taking out and then splitting from the front part of the tub but there again it will still cost u upto £100 anyway to do why this happens is mainly over filling the drum
SOURCE: Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
SOURCE: Sir, Drum of front loading washing machine making banging noise
Mine did that and had to have the washer re-balanced.
