Question about Rancilio Silvia Espresso Machine
Can I regulate the temp on our machine? our Rancilio machine seems to be to be running on too high a temperature. Meaning, we barely turn the steam wand on to steam milk (after the light goes off), an
Reading the manual, watching videos, reading blogs. Have owned many espresso machines in time and feel like we know what we're doing with them. This ones operates at a really high temp
  • 377 Answers
Silvia has two bimetalic switches that control the boiler temperature. One for brew water and one for steam. They are not exact and they can go bad. They are cheap and easy to replace. Just Google for Rancilio parts.
A much better fix (and more expensive) is to switch to PID control. Google for Rancilio PID control. The conversion is $250+ but once you've gone PID, you'll never go back. The temperature is exact, fast, and totally under your control.
Posted on Jan 17, 2015
SOURCE:
  • 3 Answers
SOURCE: steam nozzle
For the coffee - make sure the machine has heated up for at least 10 minutes. I've found the grind is the most important in getting a good shot of espresso with a good crema.
It takes trying different grinds to find what works best. When we grind at the store we choose the second finest grind from the finest - we put it to Turkish and then turn it back one notch.
On the steaming side - it takes practice. Sometimes I get froth, sometimes - I usually let the wand go near the bottom of the steaming cup and heat the milk to 160 deg. f.
Posted on Jun 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: Rancilio Epoca DE 2 group espresso machine
It could also be that the solenoid is of the wrong specifications, and hence not getting up to pressure.. Have them check both the temp and pressure cutouts again..
Posted on Jul 01, 2008
unclebuck521
SOURCE: water will not come through the steam wand
I had the same problem. I took the steam wand off, and checked for steam out of the unit. It was OK, so I stuck a thin wire up through the steam wand and dislodged what look like pieces of a green washer or O-ring.
In short...the wand was plugged.
Posted on Feb 03, 2009
EsWorld
  • 1618 Answers
SOURCE: tripping high temp cut out
The temp on the machine is set by one of the 3 thermostats on the boiler, check resistance and replace the faulty thermostat.
Posted on Mar 25, 2009
EsWorld
  • 1618 Answers
SOURCE: Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Posted on Jan 21, 2010
I have a rancilio epoca 1group. After I turn the steam wand off it keeps steaming. Would it need a new valve?
Hi Daren,
You could replace the whole steam valve wand but you don't need to.
The rubber grommet inside the steam valve is worn out and the tap wont close properly - that is why the steam is coming out.
You will find these parts with a commercial rancilio supplier.
Feb 28, 2017 | Rancilio Coffee Makers & Espresso Machines
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
On my rancilio silvia, 3 way valve not whooshing anymore. Water temperature seems low- around 180* at highest.
There are two thermostats, one for water, one for steam. Replace the one for water. You can get the themostat here
Rancilio Silvia Parts
Dec 06, 2010 | Rancilio Silvia Espresso Machine
4 questions: #1...what are the 2 hoses for: I understand that one is needed to suction the water to the pump, but what about the shorter hose? #2...I am unable to get crema. I have adjusted my grind...
1; Second hose is for expansion valve from pump, in case there is excess pressure the water returns to the reservoir.
2; Either the coffee is stale or the amount of tamp pressure is not enough. Think of your grind coarseness rocks and sand, that will help you find the right grind.
3; No
4; Yes it is normal. You need a higher temp for steam than for coffee, therefore the thermostat on the machine is programmed to get the water in the boiler to steam temp when you ask for steam, a few seconds at the most.
Aug 02, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia: The steam works only for about 10 seconds
Remove the top panel and check the 3 thermostat on the machine one of them is not functioning properly, find the wire to the steam switch and trace it to the thermostat.
Jan 26, 2010 | Rancilio Silvia Espresso Machine
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Tripping high temp cut out
Jan 11, 2009 | Rancilio SILVIAespresso&cappuccino machine
Super hot water out of the group head on my Rancilio Sylvia
My Rancilio Silva is not making the water or steam hot anymore. Is it fairly easy to replace the heating element?
Dec 29, 2008 | Rancilio Silvia Espresso Machine
Rancilio silva
Hmmm. It doesn't sound like a boiler problem. The heating element is controlled by a pressure or temperature switch. Either the switch is poorly connected or malfunctioning. Temp. switches are directly on the boiler with wires that go to a relay connected to the heating element. Pressure switches just have a tube connected to the boiler with wires to the relay.
Jan 25, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
121 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
