Question about Emerson EWV403 VHS VCR
After vhs auto rewinds both it and TV power down
My vhs auto rewinds as expected at the end of the tape. After it has finished it powers off as expected. What I don't understand is the TV also powers off. They are separate components. Not a combo type machine. This happens with the TV and VCR in the master bedroom and the TV and VCR in the kids room.
    President:
  • 1,348 Answers
Some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Posted on Jul 07, 2009
    Novelist:
  • 127 Answers
V v v v v V H ... what? VHS ... how classic.
Ummm you've either got ghosts ... or the TV's are plugged into an auxilliary electrical outlet on the VCR's - causing them to turn off when it turns off.
Do you have to turn on the VCR's before the TV's can be turned on?
I believe it was all the rage some years back to be able to program for a VCR to record a program - and the stop and shut itself off. And anything plugged into a special electrical outlet in the back of the VCR.
It might be configurable for the VCR not to turn off after playing a movie or recording one - and rewinding. Auto rewind I remember was pretty standard. All the video stores would get mad if you didn't rewind a tape.
SOURCE:
Panasonic PV-7400 VHS VCR seems to be stuck in Memory Rewind Off mode. I power on, it attempts to rewind (though there is no tape in there now) for about 20 seconds, then powers off. I've pulled
Most of these problems are caused by a faulty mode switch. If the mode switch has gone off of it's true position, then the electronics might well think it's in rewind mode even in the off position. Sometimes it's just the switch that is faulty, but sometimes damage to the mechanism has thrown off the switch.
Apr 14, 2013 | Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
My VHS tape does not rewind all the way to the
hit rewind again. does this happen to both sides?
Jul 14, 2010 | Televison & Video
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape
is it a specific one particular tape? Or is it that all VHS  tapes that you put into the VCR or Rewinder do not rewind? Do clarify
Oct 24, 2007 | Optical Coating Model 108 VHS VCR
Cannot get Tape to into camcorder
Have you tried using the cleaning tape ?
Jun 02, 2017 | Sony Handycam CCD-TRV107E Camcorder
Emerson EWV403 VHS VCR Logo
168 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
