I have a KitchenAid French door fridge Model # KFIS29PBMS00 which I purchased about a year and a half ago - the freezer has stopped freezing and the ice maker has also stopped working.....it is also l
Tried adjusting temperature of freezer - don't know what to try for ice maker not working
Mine is now doing this same thing, did you get repair and what was the cause?Mine is now doing this same thing, did you get repair and what was the cause?
You can't post conmments that contain an email address.
replace the p.t.c. overload on the compressor body of the units compressor in the rear lower end of the unit,its not letting the compressor start and then not cooling
hopefully you looked out back ...rear lower panel and checked little white condenser fan running...it really needs too to keep temp stable across the condenser coils and no overheat condition to the compressor.hopefully you wont need the $300 circuit board like I just bought
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Go to this link and you can see all the identical sized models with a right swing door. The hinges are the same so you could easily swap them;
http://www.kitchenaid.com/catalog/category.jsp?categoryId=77#85
here's a link to the user manual if you need it;
http://www.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202300253.pdf
check page 7 and 8 for how to swap a door. Page 20 gives you contact details for spare parts.
Hope this helps :)
