Question about Onkyo TX-SR605 Receiver
Hdmi audio problem from tivo hd
I am having problems with audio coming out of my tivo hd into the receiver. The audio works as long as the tv is on. I use the tivo to stream music to my receiver. No need to have tv on. As soon as I turn off the tv the sounds stops on the receiver. My only work around has been to run a analog line to the tape input. Even that does not work by itself. If I put the receiver in setup mode it will play with out a hitch. As soon as I take it out of setup, it starts skipping.
    Problem Solver:
  • 14 Answers
Your tv is new? if it is then it has a remote link, Panasonic call it Viera link, Sony call it Bravia link. Check your tv if it has that, if it does turn it off.
problem should be solved.
Posted on Dec 13, 2007
HDMI no longer working as pass through for Comcast and Tivo
sounds like your digital board is going bad. Is the unit still under warranty?
Jul 29, 2013 | Marantz Audio Players & Recorders
Hdmi screen format problems
try it on av tv it may view and explain briefly i cant understand
Dec 08, 2007 | Denon AVR-3806 Receiver
Tivo HD displays ''hdmi connection not permitted''
This happened to me many times with my Sharp 40" LCD. I am actually running 2 tvs of of 1 HD Tivo. One in the bedroom with HDMI and then through the wall into my kitchen tv via Component. ( yes whatever is on in the bedroom plays in the kitchen).. So this AM my power dropped out for a few seconds then came back on. When the Tivo rebooted I got that " hdmi connection not permitted" message. In the past, I would just reboot everything and all would be ok.. But today I couldnt get the tv with the HDMI to display the programming. It would show the tivo menus, but when I tried to play anything or watch live tv, the message would pop up again. The kitchen TV with the components was working the whole time...
So finally I rebooted the Tivo one more time. But this time I left the HDMI cable unplugged from the Sharp in the bedroom untill the Tivo was fully booted and a live channel was playing in the kitchen. I then plugged the HDMI back into the bedroon TV, and it came back on. Im not saying this will work for you, But its worth a try
Mar 08, 2009 | Televison & Video
My tivo HD is not broadcasting or recording in HD
As far as I know, you need the cable cards to get HD through the Tivo, because they're what does the HD decoding and output.
Jan 18, 2009 | Tivo HD
Motorola DCT 6200/1000 seems to only have one audio output?
There are three options:
1) Connect the Tivo using the coax output of the cable box into the cable input of the Tivo
2) Exchange cable boxes with your cable provider for one with composite output jacks. It may require you to use a Motorola box that isn't High def depending on what your provider has. I know Comcast has a Motorola HD tuner that has composite outputs as well as component.
3) Upgrade to a Series 3 Tivo. Those units are designed for High Def. Use HDMI cable hookup.
Jan 17, 2009 | Arris DCT6200 DTV Receiver
Hooking up hdmi cable from laptop to tv
yes it will. when u plug in the HDMI. right click on your desktop and adjust your graphic properties for your secondary screen
Jan 03, 2009 | Tivo Series2 TCD649080 Video Recorder
Hooking up laptop to hdtv with hdmi cable
Only if your graphics card can handle HD viewing
Tivo HD will not record when Onkyo HT-SR800 is off
Do you want to run all your cables thru the receiver? There really is no benefit for you to do this since that receiver doesn't handle HDMI audio nor do any kind of component to HDMI conversion. Might as well connect your tivo box directly to the TV with HDMI. You'll have to switch inputs on your TV between the cable box, but its not a big deal.
Feb 20, 2008 | Onkyo HT-SR800 System
Distorted HD picture when using Onkyo 605 receiver
use a hdmi switcher and the signal will be spilit up evenly between the two
Jan 02, 2008 | Onkyo TX-SR605 Receiver
Phsycadelic images
Most likely your HDMI card is defective. If you have a free component spot on your tv, use component. You'll get the same great picture as HDMI, just have to use 5 cables instead of 1. You also won't have to deal with the annoying HDCP problems and HDMI. If you do not have a free component slot, make sure your HDMI cable is securing (don't push hard) in the HDMI connector on the tivo and on the tv. Also, check your video settings to ensure they aren't cranked up from the factory, but 99% of the time, it's the bad HDMI card in the unit, which can be repaired. I recommend ccs corp in Indiana, I've used them in the past and they're great.
Oct 26, 2007 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
Onkyo TX-SR605 Receiver Logo
1,027 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
