There is nothing that we can do to help you. Next time write down all of your passwords and keep it in a place where you will not forget where it is at.
Have you ever thought that to reset the lost windows password on your
own easily and quickly without any data losing or file damaging? Well,
believed it or not, if you got software tools worked on <a href="http://www.passwordunlocker.com/knowledge/6-windows-password-recovery-solutions.html">Windows password recovery</a>,
you may finish the Windows password recovery as easily as a piece of
cake, for the Windows password recovery tools specially and powerfully
worked on recovering the lost or forgot Windows password by creating
password reset disk with CD/DVD and USB flash drive. From another way of
speaking, you could handle the Windows password recovery without
dealing with any odd computer terms or settings even though it is your
first time of using the tool.<br />
But before you are going to reset Windows password on your PC, things
you should know and take care of which sometimes can give a big hand
with your Windows password recovery.<br />
<b>Firstly</b>, it is better to create a password hint for
your pc. As we know that, password hint can be a quick start for you to
find or get back your lost or forgotten Windows password.This hint
displays after you entering a wrong password given that you once set
one. It could help you jog memory and offer clues to your forgotten
Windows password.
<b>Secondly,</b> a Windows password reset disk is taken as
the most helpful device to solve Windows password recovery issue with
which you are bothered. Though this password reset disk plays an
important role, we Windows users are forgetable to create in advance.<br />
<b>Thirdly</b>, it is recommended to set another available
admin permission account and password except the administrator account
if you are the owner of the PC. When you forgot Windows admin password,
this available admin account and password still can help you get out of
Well, by the way, if you did nothing above to prevent Windows
password recovery, take it ease. A third party software can be your
assitant. For instance, <a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker</a> is one of the most popular<a href="http://www.passwordunlocker.com/windows-password-recovery.html"> Windows password recovery</a>
tools on market for users to reset their forgot Windows password.
Featuring 100% recovery rate, it allows you to instantly reset forgot
Windows password in 5 minutes by burning a bootable password reset
CD/DVD or USB flash drive.<br />
This is hacking, not repair, AND CAN BRICK A PC. (WORSE)
it is.
That is the PW hint called a backdoor PW.
so learn go google haCKING
HACK , Hp BIOS ADMIN, WITH BACKDOOR HINT.
Resetting the System Password If you forget your password and still cannot remember it after seeing your hint, click the I still can't remember the password link. The Reset System Password page opens. To obtain access to your system: 1. In the System Key field enter the 10-digit system key located on the bottom of your gateway. 2. In the Enter New Password field, enter a new system password. In the Confirm New Password field, reenter the system password. 3. In the Enter Your Hint field, enter an appropriate hint as described under "Setting a System Password" . 4. Click Submit. Setting a System Password Setting a system password protects your gateway settings from being modified or changed by someone who has not been given permission to do so. After setting a system password, you will be required to enter it whenever you attempt to access a gateway configuration page - for example, if you try to change the gateway's broadband connection settings or upgrade the gateway software. If a password has not been set, a reminder notice is displayed when you attempt to access pages where settings can be changed. To set your system password: • Open a Web browser and access the gateway user interface by entering http://gateway.2wire.net. • Click the System tab. • Click the System Password link in the System area of the Network at a Glance panel to open the Edit System Password page. 1. In the Settings panel, click the Enable checkbox. 2. In the Enter New Password field, enter your password. 3. In the Confirm New Password field, re-enter your password. 4. Optional: In the Enter Your Hint field, enter a hint. A hint is a word, phrase, or question that reminds you what the password is. There is an I forgot the password link on the password entry page. When you click this link, it shows you your hint and allows you to enter your password. 5. Click SAVE.
Unfortunately, you can NOT access your user data and applications on the device without a password.
If you think you are entering the correct password, ensure that CAPS
lock or NUM lock is not turned on. You should try to type your password
in another application (like word or email) to ensure that it is being
entered correctly. This can help you see if CAPS lock, NUM lock, or a
sticky key is causing the password to actually be entered incorrectly.
Password attempts There's a set number of attempts before U3 locks your device and you have to reformat it. Reformatting will delete all files and applications on the flash drive.
Password hint
If you set a hint when you enabled the password protection, click Hint
in the log in window to display the hint you entered. If you did not
set a hint or still can not remember your password you will have to
reformat the drive. Reformatting will delete all files and applications on the flash drive.
It is recommended to keep a backup of all the data on your U3 device on your PC for safe keeping.
Usually, We may create a user password to protect our Dell
laptop. Unfortunately, we often forget the password then can't access
the computer. This article will tell you how to crack Dell laptop
password.
If you entered a password hint when you created the user account on your computer, then you can view the hint after entering an incorrect password. If not, and you have your original Apple restore disks, then you can reset your password by starting up from the cd. Put the CD into the drive and restart the computer by holding down the C key on your keyboard. When the computer restarts, click the Installer menu item at the top of the screen, then click Reset Password. Set the new password , then restart and voila, you're done.
