Re: Does my Amana refrigerator model number SBD20S4E have...
THis is a great question to go to the owner's manual for but I believe yours is a side by side. SOme filters are low behind the grill, others are inside:
Your model does not have a filter. You will have to add an inline water filter before supplying water to the refrigerator if you would like it to be filtered.
It should work with the filter removed because of a automatic bypass built into Amana refrigerators but sometimes even new filters or copy cat filters will not work at all because they have a defective area where they connect to your water system. http://appliance911seabreeze.com/
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
The Amana with model number SCD25TW does not have a water filter. You would have to install an in-line filter on the water supply line if you want to filter the water. If your talking about the model number ARS266ZBS, then open the refrigerator door and look at the top right hand side. You should see a filter housing with a tab to release. Once released you have to remove the filter from the housing to replace it. When finished be sure to run about a gallon through the dispenser, to flush any air out of the system.
Removing a water filter from the base grill of your Amana brand
refrigerator:
Removing and replacing a water
filter - base grill location
Filters situated in the base grill (below the freezer compartment) of
Whirlpool-built side-by-side refrigerators are relatively simple to replace.
Follow these two steps:
Grasp the filter's end and make a one-quarter turn to the left.
Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order,
making sure to first remove the red cap from the filter. Proceed by pushing the
filter straight into the slot, and then giving it a one quarter turn to the
right. Note: Replacing this type of filter is quick - there is no need to
unplug your refrigerator when replacing it. Also, this filter should be replaced
every six months.
according to the model number that you gave this particular unit does not have a filter built into it. most amana bottom freezers ahve the filter located in the refrig section on the ceiling. there is a thumb latch you push in and a cover lets down to expose the filter. then turn 1/4 turn counterlokwise to remove. if this doesnt sound right post back wiht a complete model number from the refrig and I will take another look for you. thanks for using FixYa peyton
