Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Tv won't stay on
My phillips 34'' will not stay on.I'll turn it on, it will stay on for a few minutes, then shut off. The model# is 27PT81S125.
  • 1 more comment
  • cedcreek Nov 14, 2007
    The tv just shuts off randomly after turning it on.
  • Anonymous Aug 20, 2008
    mine shuts off in about 10 - 15 minutes and wont go back on unless i unplug it and let all the copassitors drain and what not, i opened the tv in order to see if there was a clear cut power supply and there isnt but i did some resarch and there are 3 boards in there, main logic, and 2 other smaller circut boards, one attached directly to logic and other has cables running to logic, one of those needs to be replaced, which oneĀ
  • Anonymous Aug 21, 2008
    I have a 32' in Phillips and it worled fine for ever and now, when I turn it on, it shuts off within seconds, HELP!!!!!!!!
  • 129 Answers
SOURCE: Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Posted on May 16, 2008
  • 90 Answers
SOURCE: 36 tv shuts off after few minutes
have power board checked -- sounds like a short in the transformer
Posted on Feb 24, 2009
freetek
  • 5568 Answers
SOURCE: Phillips Magnavox Model 20MT1331/17: It shuts off
The poster, Jim K, is probably in possession of at least a layout of the power supply and the 'location' is likely derived from a grid used to physically find parts on a board.
220 uF is a common value for an electrolytic capacitor and the 200V is the rated sustained DC voltage it can tolerate.
The 130 volts could be caused by a capacitor that is failing and not smoothing the rectified voltage as it should.
In other words, you kind of need a tech.
Posted on Apr 14, 2009
rhozel2010
  • 269 Answers
SOURCE: My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Posted on Aug 01, 2009
  • 336 Answers
SOURCE: I have a Phillips Magnovox Projection T.V. It's
Hi,it sounds like a problem with the color wheel.The color wheel is a disc looking that the light of the lamp goes trough it to create the colors .It spins at very high rpms and through time it will begin to go bad and it will make that loud humming noise.Here;s instructions to replace the color wheel: http://guides.fixyourdlp.com/samsung/bp96-01579a.php Good luck and May God bless you!
Posted on Oct 20, 2009
I have a toastmaster model 2517 space heater. it comes on for a few minutes and then shuts off and then in a few minutes then comes back on. is that normal for that model? if not,how do I fix it?
it sounds like it is turning off when it reaches the temperature setting you have it at. turn it a little higher and see if it stays on longer.
Mar 05, 2015 | Heating & Cooling
Unit shuts down after 25 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 30, 2009 | Samsung LN32A550 32 in. LCD TV
Wont stay on turns on for a second then i hear a
I have had the same problem with every Phillips with which I have had any experience. Service required, possible DOA.
Apr 17, 2009 | Philips Televison & Video
Magnavox 15inch lcd shuts itself off
Solutions?
Hope this helps
Mar 15, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
TV DOESN'T STAY ON BUT A FEW MINUTES THEN AUTOMATICALLY TURNS OFF
lost my code book need the code for a phillips universal remote for a konka tv.
Oct 19, 2008 | Philips Magnavox Learning Universal Remote
Philips/Magnavox TV, model MS3250C321 shuts off randomly.
TV shutting off automatically means its a problem with the Lamp. Contact Pioneer or any local tech shop or Best buy and get the same replaced.
Turning off after specific time : Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 17, 2008 | Televison & Video
Televison & Video Logo
385 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
