Question about Garmin nuvi 350 GPS Receiver
Touch screen I can,t get the screen to respond
Re: touch screen
You can reset the touch screen
turn the unit off then push the power switch to the left and hold it there for 30 to 40 seconds then follow the promps on the screen to reset the touch screen
Posted on Jan 11, 2008
0 characters
3 Points
720 screen does not allow " i agree" to be pushed. screen was un responsive after l;ast update. Did complete reset . reloaded new applications. after the screen does respond to menu where you choose...
A lot of people are having the same issue after the update. Since you cant connect it to computer, my best advice is to get it replaced unfortunately.
Nov 18, 2013 | Tomtom GO 720 GPS Receiver
Touchscreen not responding
If the touch screen of your phone is not responding to touch then it means you have to calibrate the screen to get it working once again.
To calibrate your screen, be sure that the nuvi is properly charged, then you follow the steps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi.
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears(white screen with touch dot),
  5. Then follow the on screen instructions.
That should do the job for you. hope this helps.
Jan 10, 2011 | Garmin nuvi 255W GPS Receiver
Touch screen not responding to touch
Please see this link:
- Jim
May 19, 2010 | Garmin Nuvi 660 GPS Receiver
My garmin (nuvi 670) touchscreen does not respond to any touch
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
Garmin Nuvi 255 2008 screen not respnond to touch
There should be a reset on it and it should bring it back.
Dec 25, 2009 | Garmin Nuvi 255 GPS Receiver
Touch screen on my nuvi 670 is no responding
The screen needs to be replaced. This is a common problem with the newer production run SHARP touchscreens. Please see this link for more info:
- Jim
Oct 19, 2009 | Garmin GPS Devices
Touch screen not responding when using stylus.
Is it just possible you left the Navman mounted on the screen in hot weather whilst away from the vehicle? I made a little white jacket for mine with a heat reflecting liner.
Nov 17, 2007 | Navman ICN510 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
122 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
