Question about Samsung DVD-R155
Finalizing dvd after recording
I was finalizing the dvd after i have recoreded on it like u have instructed through the disc manager screen and so on... was loading and then all of a suddent the dvd player made a funny nosie then the words 'system in error' came up and then just froze. now i can turn my player on or off plus i can even get the disc out. what just happened?
I have also had this problem as well, and have also found that when it is preparing the disc to begin with the player will lock up.
I've only found this problem on dual layer DVD-R discs. I've yet to get to the bottom of this issue BUT looking back at the manual there is a section around compatibility and it has the the following statement:
"A 8X speed DVD+RW or greater disc can be played, but
maximum recording speed is 4x."
The discs I am using are 8x which looks like it could be the problem. I am wondering if the discs are having issues with running at the lower speed.
It may be worth checking the speed of the discs that you are using.
Posted on Dec 11, 2007
I got a new machine, when I transfer from VHS to DVD-R it records, but will only play on the machine I recorded on, it doesn't load on other DVD players, why is that?
You need to FINALIZE the DVD-R you recorded in that unit for it to be playable on other DVD players. This function should be part of the on-screen menu for your unit. (in Panasonic DVD recorders, it's under DVD MANAGEMENT in the FUNCTIONS menu).
If the disc you recorded is already loaded, but stopped, press SETUP on your remote - an on screen menu should appear.
Using the UP/DOWN arrow keys, select DVD MENU and press ENTER. Use the UP/DOWN arrow keys again to select FINALIZE and press ENTER.
A message box will popup 'Finalize disc?' use the UP/DOWN arrow keys to select YES then press ENTER. Finalizing should start and may take a while to complete.
Once complete, the disc is now playable on other DVD players. (from page 32 of the owners manual with the heading 'PLAYING THE DISCS IN OTHER DVD PLAYERS')
Feb 10, 2013 | Toshiba DVR620 DVD Recorder/VCR
Need to know how to finalize recorded disc so that it can be played in regular dvd player
You can record and finalize DVD+Rs one time. After you fill a DVD+R or
complete all the recordings you want on a single DVD+R, finalize it.
Otherwise, the DVD+R will play only on this Recorder.To play the Disc on
other DVD Players, you must finalize it first.
Once you finalize a DVD+R, you cannot record on it anymore or make
editing changes.Therefore, make sure the Disc is as you want it before you
finalize it.
Press SYSTEM MENU. Press
; to select in the top left
corner of the menu bar at the top of the TV screen.
Press CH-
9 repeatedly to select in the second screen,
then press
Press CH-
9 repeatedly to select Finalize disc. Finalize disc
appears in the menu only when an unfinalized DVD+R is in the
Recorder.
Press OK.
"Finalizing" will appear in the menu.The process may
take a few minutes.
When finalization is complete, the Index
picture screen will reappear.
You cannot unfinalize a DVD+R, and you cannot record or
edit the DVD+R after you finalize it.
A DVD+R will play on other DVD Players only after the
Disc is finalized.
Mar 22, 2011 | Philips DVDR75 DVD Recorder
How to finalize discs on DMR ES 10
It should be a menu option. Press [FUNCTIONS] button on remote to access on-screen menu, then press the UP or DOWN arrow buttons to select 'other functions' and press [ENTER] or [OK] depending on your remote. Then using the menu, enter your disc name, etc., then with the UP or DOWN arrow buttons again, select [FINALIZE] - this should make (example DVD-R) the disc - compatible playback ONLY for all players. You are basically looking within the on-screen menu for 'finalize' option. You should get a popup dialog asking you if you would like to finalise the disc - if you choose 'yes' the operation will begin.
Do you have the instruction manual? if so, refer to page 30 - 32 - disc management. I hope this helps a tiny bit. If you don't have the manual, you can download it as a .pdf free.
http://service.us.panasonic.com/OPERMANPDF/DMRES10.pdf = download this if you do not possess the original operation instructions.
Feb 21, 2011 | Panasonic DMR-ES10 DVD Recorder
HOW TO FINALIZE THE DVD CASSETE AND CONNECT TO T.V SET?
Finalising a disc enables the disc to be played on any other compatible machine. By doing this it changes the disc format so that you can no longer record to it turning it into a Play Only disc. On your Panasonic DVD Recorder you can record to many (if not all depending on the model) of the following DVD Disc formats to the limit of their capacity over multiple occasions. The disc in question can be played back and recorded to on the DVD Recorder during this time but until it is finalised it will not work on any other machine.
DVD Formats: DVD-R, DVD-RW, DVD-RAM, DVD+R, DVD+RW.
How do I Finalise my disc?
  1. When you have finished the initial recording stop the disc and press the ~FUNCTIONS~button.
  2. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "To Others" and press~ENTER~.
  3. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad Scroll down to "DISC MANAGEMENT" and press ~ENTER~.
  4. When the disc management screen opens you need to use the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad to scroll down to "FINALIZE" and press ~ENTER~.
  5. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "YES" and press~ENTER~.
  6. Using the ~UP, DOWN, LEFT, RIGHT arrows~ on the keypad select "START" to begin finalizing the disc, please note by pressing start here you will no longer be able to record or edit the disc being finalized.
Finalizing may take up to 15 minutes.
Do not disconnect the mains power in this time. A message appears when finalizing is finished, press the enter button when this appears. It will now play on other compatible machines.
Apr 23, 2010 | Panasonic SDR-H40 HDD Camcorder
Can't find finalize program on on screen menu
Select DVD drive, use right navigator and look for DVD management  page under other functions. That should offer you a finalize disc choice.               Or if disc is not full, try adding one more file small enough to fit, and finalizing should be automatic. Your disc may not be able to be finalized if your EH 55 didn't create it in the first place.                   Ricardo
Mar 18, 2009 | Panasonic DMR-E55 DVD Recorder
Can not get the 'Finalize Disc' option on the
Do not worry about no Finalize Disk option. You may have it under another guise.
A recording session can be specofied as open ( Default ), or closed. If closed DATA cannot be appended to the disk.
No matter how many sessions have been written, if the last session is closed no more can be written. Your software automatically finalizes each session, in fact must.
Feb 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
Dec 03, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Wont play dvd discs
Hi all.
I have 'a' solution. It is a pain in the neck but what I do is just keep closing the drawer after the message "this disk can neither be played or recorded, please check disk" comes on screen until it does what it is meant to do.
I am only doing this to clear off the hard drive then I am going to buy another machine.
Nov 20, 2007 | Samsung DVD-HR730 DVD Recorder/HDD...
Samsung DVD-R155 Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
