Question about RCA F32668 32" TV
RCA F32668 model tv flicking channels on its own
Please help me.
I have an RCA F32668 model tv and Sunday afternoon, it just started flicking channels on its own.
I've tried unplugging and trying to do something with the programming but as soon as I get in the menu, it goes automatic on that as well. Going up and down, up and down.
It seems like its on autosearch or something and I've tried to get it to do that as well to no avail.
  • Anonymous Jul 15, 2008
    As soon as tv is turned on manually or remotely, it starts cycling through the channels continuously. If a specific menu button is selected, it starts cycling through the menu options continuously.
Tuner Has Bad Solder Connections Internally
Posted on Nov 15, 2007
I forgot code for parental lock on my RCA F32668 32" tv, please help. Thanks
RCA TV Parental Reset Code: First select parental control from the menu. You will be asked to enter your password. Press and hold the "volume +" and "channel +" buttons on your television (not the remote) for 8 seconds. You will see a message that the parental controls have been unlocked.
How To Unlock Your TV Parental Control Password
Jul 07, 2015 | RCA Televison & Video
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
Mar 14, 2011 | Televison & Video
Samsung plasma. adding channels to favorites.
open tv manual setup cable to ant
auto scan channels
Aug 13, 2009 | Samsung 50 in. Plasma TV
Hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
Dec 28, 2008 | RCA HD52W59 HDTV Projection Television
Not all channels available
Sounds like a bad tuner or more commonly the connector on the tuner is loose and or broken.
Jun 25, 2008 | RCA D52W19 52" Rear Projection Television
Flicking Channels
I HAVE THE SAME TV WITH THE SAME PROBLEM. I'M NO TECHNICIAN BUT I TOOK THE BACK OFF AND DISCONNECTED THE CIRCUIT BOARD THAT CONTROLS THE REMOTE SENSOR AND THE BUTTONS. THE TV STOPPED FLIPPING BY ITSELF. I'M CURRENTLY TRYING TO FIND A REPLACEMENT PART.
Aug 28, 2007 | RCA F32668 32" TV
DVD player not showing on tv
I'm not sure, but, if you use the channel down button on the television, the set may go to the video inputs. If not a local retailer should have an inexpensive universal remote that would work on this set and have an input or tv/video button. If you use a cable box, the remote can be programed also. If you need more help, reply to this post and I can come up with more solutions when I get to my shop next week.
Aug 06, 2007 | RCA F32668 32" TV
32" model# F32668
The F32668 uses the CTC203 series chassis and I usually see 2 problems when the set will not run. The first is poor solder joints on a small coil near the horizontal output transistor, but if thats the case the set tends to run for a while and randomly shut off. When the set clicks and never runs I usually find that the flyback (high voltage) transformer has shorted out inside. In this case the flyback should be replaced by an experienced tech.
Aug 05, 2007 | RCA F32668 32" TV
RCA F32668 32" TV Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
