Machine still works perfectly but leaks and the seal is perished. I could also do with a new single dose filter head if anyone knows where I can buy the parts as there is no manufacturer details anywhere on the machine or inside it, as I took it apart to look. The model number is 376D3320 Pump Espresso Coffee Maker
SOURCE: Breville Die Cast 800ESXL
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk). Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water). You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
SOURCE: instruction manual for delonghi combi espresso/filter coffee maker bc0255
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Your manual is listed on this page and you will be able to download it.
Good Luck.
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
SOURCE: Need a coffee (not espresso) carafe for West Bend 55129
This page at the West Bend parts site shows all the parts, prices and you can even download a manual if you need it.
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Problem solved. The machine is actually Branded as Woolworth's, but after a LOT of research it turned out to be a Breville Modena espresso maker, so I have located a retailer for the part. Thanks to all who took the time to read this.
I have had this machine since 2003 and still works a charm! Well it did until the rubber seal split this weekend. Having dismantled in the knowledge of woolworths demise I was at a loss until I found this thread. Thanks a million and hope to find the parts now.
