Cars & Trucks Logo
L
Louise Johansen Posted on Jan 10, 2015
How do i turn of the set up menu on my pioneer mosfet 50wx4 rdf ? every time i start the car et starts up in set set up menu and i have to do everyting all over again . i have had it for 3 years and i
I have tried everything as far as i know
A
Anonymous
There is two supplies to any car radio sometimes three
+12v all the time {to keep its memory}
ignition on {running}
and standby
some radios even have a backup battery you need to replace
but i think one of the perminent supplies isnt good too the radio
so check the fuses on its rear
and check its getting always 12v from the battery
check for a good ground
or any corrosion on wires etc...
Hi. I have a 2007 Mahindra 2.6 Crde.. Whilst driving, the vehicle engine light comes on and have to switch the vehicle off and on for the light to go off. This light comes on noisily when I press the...
Limp home - Target Follow Malfunction Your vehicle has gone into "limp" mode for some unknown reason. This particular code needs special attention from your local dealership and/or your favorite garage that handles things of this nature. Sorry I couldn't have been any better help than this but I hope you get it resolved. To give you a bit of info on the issue: Possible causes Faulty Electronic Throttle System (ETS) Motor Faulty Electronic Throttle System (ETS) Electronic Throttle System(ETS)unit Electronic Throttle System(ETS) harness is open or shorted Electronic Throttle System(ETS) circuit poor electrical connection
Jesus loves you, John 3:16-17
1helpful
2010 equinox. oil change due warning won't go off after oil change. how do i reset?3 times gas pedal, engine off then start,100% thanks'
Turn IGN to ON/RUN but don't start engine
Fully depress pedal 3 times within a total of 5-secs
If you have the Driver information center
Press the DIC menu button until Remaining Oil life displays
Press and hold the set/clear button until 100% displays
Turn the key to OFF
Timing on 85 toyot corolla / et up
If you mean how to install timing belt, I'm not sure on your corrolla, but on my old tercel I turned the crank pulley so that cylinder 1 was at its top height (by feeling with a screwdriver in sparkplug hole) then turned valve pulley until first valve was open (with valve cover off) then aligned the timing belt that way. It didn't work. Then I realized that the cylinder has 2 top positions, one for "compress" stroke and one for "push out exhaust", so I turned crank again to bring cylinder one to top height, aligned belt, and it worked, car started.
Then I realized that crankshaft pulley had a ''timing mark'' (a kind of little notch) on it and that it aligned perfectly with a mark on engine, just to prove that I had done it right, "by hand".
Hope the info helps ya !
2004 grand am won't turn con but all lights work,et
Hi Alicia with the Grand Am...:) Can you start your Grand Am by jump starting from another car and battery? First check cable connections on the battery...if dirty or corroded (even broken) the connection will not support the cranking power and will not turn over the motor...also inspect the battery to see if the battery casing is swollen...this is a sign the battery cells are wearing, and a battery replacement is necessary...be sure to have your battery checked ( a free service at most auto parts stores) before you could be stranded...Hope this helps.
2helpful
What is an ETS light keeps flashing what does this mean
This a technical bulletin for your car
Hope this helps, if it does please leave feedback
Good Luck
File In Section: 5 - Brakes
Bulletin No.: 63-50-09
Date: March, 1996
INFORMATION
Subject:
"ETS OFF" Indicator Lamp On with No DTC's Set Models:
1996 Buick Skylark
1996 Chevrolet Cavalier
1996 Oldsmobile Achieva
1996 Pontiac Grand Am, Sunfire On vehicles equipped with Enhanced Traction System (ETS), the "ETS OFF" indicator lamp may come on and ETS and Cruise Control might become disabled. There may be no ABS or PCM Diagnostic Trouble Codes (DTC's) stored and there may be no "Check Engine" lamp on. This condition has caused a high rate of unnecessary IPC replacements.
The PCM sets a Type "C" or "D" FAILURE RECORD which sends a message to the Electronic Brake Control Module (EBCM) to turn the "ETS OFF" indicator on and to disable ETS. The PCM can then disable Cruise Control, but may not turn on a corresponding "Check Engine" lamp. These Type "C" or "D" Failure Records are not stored in the normal Current or History menus.
41807575
The technician is instructed to check normal operation of the "ETS OFF" switch and the ETS system. The technician is then instructed to check for Failure Records and directed to Section 6E3-A of the Service Manual, see chart. When the PCM Failure Record is corrected, normal operation of the ETS system and Cruise Control should return.
Hi i drive 94 nisssan maxima for my second job which is a driver et pizza store. 2 days ago i stopped to give the order and when i came back and started the car it didn't run. i mean battery was good i'm...
The click was the starter solenoid, first sign that it could go out any time, you might want to think about replacing it, more so with your second line of work, good luck.
I have 2002 xg350 and the water pump went out and then rolled the timing belt off and bent the valves. Pulled the heads and had repaired. reassembled and it ran fine for 24 hrs. and then it popped code...
Hi
The ETS limp home valve may be on. Clean the throttle body and intake runners with intake cleaner with engine running. Then do a ETS initialization as follows:
ETS INITIALIZATION PRCEDURE:
Turn the ignition key to the ON position (for less than one second) and quickly turn the ignition key back to the OFF position.
Wait 10 seconds in off position.The ETS Module performs the INITIALIZATION process and at completion you will hear a click from under dash. Turn the key on for 1 second then start the vehicle.
Hope this helps - Steve
2answers
Ets off light keeps flashing
Likely time to change your brake pads which is the most common cause for the ETS light to start emitting on non all wheel drive vehicles.
Top Mazda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mazda Expert? Answer questions, earn points and help others
