Computers & Internet Logo
Michael Bourbeau Posted on Jan 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will I create my records and files in Adobe Illustrator or maybe Photoshop?
I want to make printing of files and maps. So I Can you help me by giving my answer.
baadtaste
Level 2:
  • Expert 126 Answers
  • Posted on Jan 17, 2015
baadtaste
Expert
Level 2:
Answers
126
Questions
Helped
24528
Points
222
Hi. It is not clear what you want to achieve. But it sounds like you want to make a Contact sheet. To do this Adobe Bridge is the right tool. How to do it varies a bit depending on witch version of the software you have. If you have CS6 - choose Output from menu. If you have CC you might have to install an output module. See link below:
Install Adobe Output Module
Error opening file in Adobe Illustrator
Create New Illustrator File:
    -Double-click the Adobe Illustrator icon on your desktop to open the program. Click the File drop-down and select the "New" option.
    -Choose the size and color mode for the file and then click the "OK" button.
    -Click the File drop-down and then select the "Place" option. Choose the "All Formats" from the Files of Type menu when the Place dialog box appears.
    -Select the damaged Illustrator file and then click "Place." Enter a new name for the file and then click "Save." This will create a new Illustrator file with information from the damaged file. or you can try to use illustrator recovery , this is nice PAID service . i wish you good luck
How to recover corrupted ai file of Adobe Illustrator
1helpful
View content of Illustrator?
The AI file is Adobe Illustrator file and created by Adobe Photoshop application, as per my advice you can try to open your corrupted or heavily damaged AI file with different Adobe Photoshop version because it can be happen your AI file is not completely corrupted, may be any chance to view your AI file if this technique not work then I personally recommend a third party tool I give you a link where you can download free AI viewer software and you can open and convert you AI file by this link.
http://www.freeviewer.org/ai/
Thanks
1helpful
2answers
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
How do i use adobe illustrator
u can create design in Photoshop and then switch through
file
export
path to illustrator
Got CS2 running on PC under WinXP, and have been using quite happily for over 3 years. Recently the menu option File | Open Recent... shows an unchanging list of files, irrespective of which files I have...
Save your work and close Illustrator. Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings. (Your version of Illustrator will be in the foldr name.) Inside this folder is a file called AIPrefs. Drag this file to the trash, and restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
You can also reset Illustrator's preferences by holding down Shift + Control + Alt while launching the program. If you get a dialog asking if you want to delete the Adobe Illustrator settings folder, click yes to proceed. Restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
1helpful
2answers
Pls give me a basic tips using a illustator
Another helpful site would be http://udemy.com for great illustrator tutorials
Also you can look for inspiration on these infographics that I have created:
99 Dollar Infographic Design from Infographicly org
I created a logo using Adobe Illustrator 10 and drag and dropped it in a Photoshop 7 file to be printed. The photoshop 7 file was 300 dpi and when I brought the logo in in got really small so I increased...
Resolution is a hard thing to grasp. I'm guessing the original logo created was either a low DPI and/or a small physical size. For example if you create a 1in x 1in logo at 300 DPI and increase the size to 4in x 4in at 300 DPI - the image does not contain small enough pixels to give a quality image (1 pixel is translated to 4 giving jagged edges). I hope this helps.
1helpful
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
3helpful
2answers
Adobe illustrator
Hi Mekarim,
You may try this:
1. Open the C:\Program Files\Common Files\Adobe folder and look for a folder starting with Type and meaning Type support; in 10 it is called TypeSpt;
2. Create a namesake folder on your Desktop;
3. Move all the contents to the namesake folder.
Please report back, including the name of the folder.
Ziad
Dubai
[email protected]
00971 50 2511165
1helpful
Copy and paste issue
Why not export the image as a jpeg or tiff and the open it in photoshop, that's what I do, It works fine.
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
