Most of the time that this happen is because the printer is just dirty or have something blocking the railway. I recommend that you take it apart, and get on of those air compressor that are sold in Office Max, use to air blow whatever is loose in the printer. After that check to see if there is any piece of paper stuck.
After that it should work OK again, if it doesn't, then there could be a plastic part broken and is out of alignment.
SOURCE: paper will not feed
Check for a jam again somewhere in printer unit, rollers, teeth, down back in paper feeder area. I thought i had no jam in my unit either until i got a torch and found the tiniest slip of a shred barely noticeable right in the middle of the teeth/roller. Remeber to turn it off after this, to reset it.
SOURCE: MP160 Error E3
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
SOURCE: not feed paper
it may be that the paper is too slick for the grabber to access...try a little heavier bond paper(not the same as copier paper, which is SLICK.
http://tinyurl.com/6qcpgy
SOURCE: red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
SOURCE: printer wont feed paper through to print on
there are a lot of steps that u need to follow.. I tried to get the detailed link but it didnt seem to work properly.. so try this link below.. http://tinyurl.com/2kdp28 once on this page.. go to support & service.. and search for FEED PAPER... and select the second answer there.. and follow steps there.. let me know if this was helpful to u.. regards, guru
