Question about Fisher Paykel EcoSmart GWL15
Defective power button?
I tested the power in the machine and I have 120 volts ac. There is no light at the power botton when pushed. Nothing happens what so ever. No sound and no lights.
  • 1,294 Answers
Re: defective power button?
Is there power in your wall outlet, try something else there. Next try the fuse in your washer plug, may have blown.
Dont forget to rate.......
Posted on Dec 28, 2007
0 characters
3 Points
Ge washer GFWS3500L0WW Has no power on the control board...Its dead...I get 120 volts at the door switch but nothing back out that returns to the control is this a faulty door switch?
Not likely that the door switch is killing the power to the control board.
It may stop the machine from going through cycles, but it shouldn't turn off the control. It's probably that the door switch has one side always powered and they connect it to the other side of AC when they want it to engage or the relay for the door switch happens to be stuck in this mode when the control board went out.
Jul 21, 2016 | GE Washing Machines
My frigidair flexcare washer. Is there a reset button incase it was accidently overloaded?
Check the Door if the door safety switch is not made the Drum will NOT function ( Agitate Spin ) check nothing is preventing door from closing completely check nothing is in door switch if all looks OK try pressing down on the door were the door switch activator is just might not be making contact , if you know how to use and have access to a test meter you can check for continuity in the door switch can also test by jumping out the switch if you know how Caution it is usually 120 Volts AC so only perform electrical work when machine is unplugged
Apr 17, 2016 | Washing Machines
Power is on light is ok but not start, what to do please me
Eddie,Check lid switch and bypass if you can,timer or control board may need tested and replaced.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 21, 2016 | Washing Machines
I have a Whirlpool solid-state Mark2 top loading washer powers on but just clicks when I push the run button
Pull the unit away from the wall where you can get behind it. Take the access panel off . From the back the control panel. If you have a good multi-meter. Set it on 200 volt AC. Check power at a easily accessible power out let. If you get between 110 and 120 volt reading .your meter is good. Check voltage at starter button with the unit plugged in have someone try the button while you checking for power. If you're not familiar with electrical wiring might have to call someone who is. Chances are your on off switch is bad or the timer is .
Aug 02, 2014 | Washing Machines
Why doesnt my washer put out cold water
either the hose screen inside the fill hose is plugged with lime/rust/etc. or the water solenoid is defective or not getting power from the controls,on some fill valves there is a thermistor that senses water temps as it fills and this part could also be defective,you can test this valve with a cheater cord to see if it opens,or unplug the machine and use an ohmmeter to test the solenoids coil for continuity,if good plug it in and check for voltage(normally 120 volts A.C.)on the solenoids terminals during the fill cycle
Nov 19, 2012 | Amana Washing Machines
My LG Washer isn't working. The little chime that rings whenever it is turned on happens but then NOTHING else. No lights, no codes, nothing. I spin the dial but there's nothing, no noise and no lights....
the machine has suffered a power failure?push and hold the main power button plus another button together hold both buttons in for about 60 secounds the machine should reset.adrian.
Mar 16, 2011 | LG Washing Machines
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
No power
test the outlet with something else (lamp, voltmeter, etc) If no power, check the breaker. If you have power, try holding the button in for a few seconds, but make sure the door is latched well first. Try to start it on a different cycle.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
184 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
