Question about Compaq iPAQ MP2810 Multimedia Projector
Cannon Projector LX-V5
We are facing problem with our projector. It is all pink in colour now. kindly solve the problem as we have a presentation now
Re: Cannon Projector LX-V5
Could be that the colour wheel inside of the unit has jammed or failed and it might be stuck on one colour, just a thought.
Posted on May 29, 2009
  • 563 Answers
Hi guys
Try using a different signal cable.
If this doesn't solve your problems , you will most probably be looking a new Mainboard.
Very expensive part to have replaced , so try and get a dealer that can repair.
Posted on Apr 01, 2008
0 characters
3 Points
Sony projector projecting pink
If the menus are still the correct colours then the issue is with the source signal. If the menus are affected then this is a problem with the UV filters in the projector. Check this, then post another question with your findings.
Sep 07, 2014 | Sony VPLMX25 3LCD XGA PROJECTOR VPLMX25
Projector image has a pink tint to it
Usually colour problems like this are due to one of two things:
1. poor connection at either end of the cable, or
2. a damaged connecting cable between projector and computer.
Check these first before getting the projector to a technician.
Aug 16, 2011 | Vivitek H1080FD DLP Projector
Screen is turning a pink/purple colour
You should firstly test the projector using some alternative input sources, and using different cables to establish that the pink/purple tinge is consistent across all inputs.
If it is, then your projector is in need of professional repair. You should be able to contact 3m here who can advise who their local repair agent is.
Best of Luck
Feb 15, 2011 | 3M S20 Multimedia Projector
My Nec VT700 is projecting a pink image. How do I fix this?
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | NEC VT700 Projector
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Picture colour is wrong. Too much green and pink.
first reset the settings to factory default. then swap out the cable. if you still have trouble, replace the colorwheel.
Mar 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
Multiple reddish pink vertical lines going from
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
Optoma h27 colour issues
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
May 07, 2008 | Panasonic PT-LB10VU Multimedia Projector
Sharp Notevision XR-10S Multimedia Projector shows pink on the screen
Hi there
If the colour only shows pink when a source ( i.e. vga or video ) is inserted. Firstly check for a faulty cable - 99% it is the problem. Otherwise you'll have to take it to a repairer as the input could be damaged.
Mar 25, 2008 | Multimedia Projectors
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Compaq iPAQ MP2810 Multimedia Projector Logo
462 people viewed this question
Top Compaq Multimedia Projectors Experts
ray gallant
Are you a Compaq Multimedia Projector Expert? Answer questions, earn points and help others
