Dryers Logo
D
Daniel Posted on Jan 10, 2015
Why does my dryer start but quit a second later
Model # DLE33ORAW
perrywilliam
Level 1:
  • Contributor 25 Answers
  • Posted on Jan 12, 2015
perrywilliam
Contributor
Level 1:
Answers
25
Questions
0
Helped
12341
Points
47
If it quits immediately after you let go of start button, then it isusually a bad timer or control board. The motor gets all its power during start from the start button or start relay, but once it is up to speed the motors centrifugal switch will flip, getting power from the run circuit. If there is no power supplied to run circuit (like when timer is off, or door is open) then the motor shuts off.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
1 Related Answer
RepairNinja
RepairNinja
  • 98 Answers
  • Posted on Apr 19, 2010
SOURCE: whirlpool estate electric dryer model teds680eq1
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
My Whirlpool Duet Steam dryer starts, but then stops a few seconds later. What is this indicating?
Likely a broken sensor or bad power relay... There are no error codes along with the failure? Model #? Help Me Find My Model Number RepairClinic com
Dryer starts about 45 seconds into the cycle lights come on and then it starts beeping like the end of the cycle. 10 seconds later off. Very warm on top of the machine.
See my tip for buzzing dryer. Check Owner's manual, Troubleshooting. Sounds like air is not moveing and High temp cut off saftey switch doesn't like the lack of air flow. Duct clean? Check air flow from the outdoor vent. Clean vent tube/s
Dryer starts up runs for a second and stops a few minutes later starts up runs a second or two and stops
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Top Dryers Experts
john h
