hi,
To use this to crack activation on Office 2007, you need to install Office 2007 without any serial number or product key. If you have installed Office 2007 with a product key or serial number, do the following to clean remove Office 2007 of product key:
Run Register Editor by clicking on Start -> Run, and then type “regedit” in the Open box and press Enter key.
Navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration
Note that inside the registry key, there should be another subkey that resembles the following:
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{90120000-0030-0000-0000-0000000FF1CE
or
HKEY_LOCAL_MACHINE\Software\Microsoft\Office\12.0\Registration\{91120000-0011-0000-0000-0000000FF1CE
If there is more than one registry entries or subkeys that reference Microsoft 12.0 registration, open up each subkey, and then identify the product by the ProductName value data until you locate the subkey for the product which you want to remove the existing product license key.
For example:
ProductName=Microsoft Office Professional Plus 2007 ProductName=Microsoft Office Enterprise 2007
Once found the correct registry subkey, delete the following values:
DigitalProductID ProductID
Once Microsoft Office 2007 has been installed with no product key, proceed with the following steps:
In Windows Explorer, brose to the following folder:
C:\Program Files\Common Files\Microsoft Shared\OFFICE12\Office Setup Controller\Proof.en\
Right click on Proof.XML file, select “Open With…” in the right click menu.
In the “Open With” window, select Notepad to be used to open the XML file. In Vista, if you can’t see the Notepad option, simply double click the “Other Programs” to unhide it.
Scroll down to the bottom of the Proof.XML to locate the following lines:
</Feature> <Feature Id=”SetupXmlFiles” Cost=”1248′> <OptionRef Id=”AlwaysInstalled”/> </Feature>
Change the AlwaysInsalled to neverInstalled so that the line looks like following:
<OptionRef Id=”neverInstalled”/>
Save the Proof.xml file. In Windows Vista, you may need to take ownership and grant full access permission to yourself before able to modify the file.
You can now launch Microsoft Office 2007 application such as Word, Excel, Powerpoint, Outlook and etc without prompting for activation
Comments:
Jul 07, 2009
- hi,
or
For example:
Jul 07, 2009
- hi,
or
For example:
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Microsoft Office Professional
Microsoft Office Professional 2007 Full Version for PC
When I open a word or excel file over network from another computer, word starts and then waits 1-2...
(More)
When I open a word or excel file over network from another computer, word starts and then waits 1-2 min and then it opens file (even the smallest ones). If I copy the same file over network and then open it it's instant.
