Question about Rancilio Silvia Espresso Machine
Hi - I have a new Rancilio that I just opened today. Steam is coming but not enough water for a brew
  • 80 Answers
Maybe is just air in pump,try prime water on steam wand.open steam valve and press button for make espresso,keep couple seconds
Posted on Aug 22, 2009
SOURCE:
Rancilio coffee machine .no water coming out of the group head . steam coming of the group head
Hi Ewah,
If you are getting steam from the group and no water when you turn on the water button - then you may have a group blockage.
The fix depends on the type of machine you have.
If it is a commercial type - then call in a qualified coffee technician.
If it is a domestic type like rancilio sylvia, the you could try to descale - maybe too late, but worth a go.JURA descaling tablets
If when descaling, no water is coming from the group try leaving the steam tap open when asking for water.That way you may get the descaler liquid moving inside the boiler and it may clear the solenoid valve blockage.
If no joy with that you may need to replace solenoid valve.
230V 9W PARKER SOLENOID
Domestic machines need regular descaling to avoid group blockages.
Mar 18, 2017 | Rancilio Coffee Makers & Espresso Machines
Steam comes out the grouphead
It should not leak steam out of the grouphead. The three way valve is leaking.
First of all if it is new, get it fixed under warranty. The three way valve is a replaceable item.
On the other hand if you are like me, you can try a back flush with just a tiny bit of coffee machine detergent like "Joe-Glo". The directions might say not to do this but if it is my machine, it's my machine
  1. Get a rubber disk for back flushing. Any place that sells the detergent should sell the disk.
  2. Put the disk in the portafilter and add just a few grains of detergent.
  3. Install the portafilter and "brew" for about 20 seconds, then switch of for 15 seconds or so..
  4. Refill the water reservoir as needed.
  5. Repeat the "brew" cycle until you get "detergent water" in the catch pan. It may take 6 to 8 cycles.
  6. Remove the back flush disk from the portafilter, reinstall, and run a couple of normal 30 second brew cycles to flush detergent out the valve and grouphead.
If this was a coffee maker in service for a while and might have a water scale buildup, I would do the same thing but I would dissolve some citric acid in the water reservoir and descale the boiler, valve, and grouphead at the same time.
Feb 25, 2014 | Rancilio Silvia Espresso Machine
My 6 to 7 year old Silvia stopper making steam today. Do I need to send it out and where or is a diy
If it comes up to brew temperature, you have to replace the steam thermostat, which is a DIY. There are 2 thermostats on top of the boiler. The one with the red dot is the brew thermostat, so the other one is the one you need to replace.
Aug 22, 2010 | Rancilio Silvia Espresso Machine
I've had my Rancilio Silvia Espresso machine for about a year and a half. I use it every day. Today, it won't heat up. It turns on but will not heat up. Is there a reset button? Help, please.
Hi
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also another problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
If none of these things work check the heating element with an ohms meter. The reading in the terminals should be from 12 to 16 ohms. If no reading the elements is bad and you have to replace the boiler.
Jun 22, 2010 | Rancilio Silvia Espresso Machine
My Silvia no heat-no steam. water goes through
HI
If your lucky.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat2_bing.gif is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Jan 21, 2010 | Rancilio Silvia Espresso Machine
Rancilio Silvia indicator light not turning off
Hi
Dec 25, 2009 | Rancilio Silvia Espresso Machine
MY SILVIA NOT WARMING THE WATER. I LEFT THE MAIN SWITCH "ON" AT STEAM FUNCTION WITH THE SCREW-KNOB OPEN AND THE STEAM SWITCH "OFF". TOMMY.
Hi
If your lucky.
There is a reset button inside on the front side of the boiler (you have to take the top of the machine off. There are 4 screws and remove the water tank). It is located between 2 black wires and is a red button. Push it in and test. There is also an other problem that you might have. If the brew thermostat is bad it won’t heat. To test for this, push the steam switch and wait 15 seconds. Then open the steam knob and push the middle button and see if the water is warm. If it is then you need a new brew thermostat. That is the thermostat that has the red dot on the top. It sets on top of the boiler next to the steam thermostat. If you take the top off, make sure that the machine is unplugged.
Dec 22, 2009 | Rancilio Silvia Espresso Machine
Sylvia still makes great milk for steam but on Saturday it stopped producing hot water for expresso. What do I do? I live in North Tas
Hi
Nov 15, 2009 | Rancilio Silvia Espresso Machine
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Apr 20, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
165 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
