SOURCE: TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v
electrolytic capacitors in the power supply board located above the
power switch. They are likely bulging out at the top and failed. They
are the three in a row at the top - center of the board, located
between the two black heat sinks. Make sure you get caps rated for 105c
degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will
work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from
partsexpress or digikey or any good local electronics store. Your local
radio shack may have them but they won'y be 105c and thus may not last
long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
SOURCE: On/Off blue light blinking, TV won't come on.
Ur power ic inverter board is dead.
U need new one.
Testimonial: "Thanks for the advice. Will try it."
SOURCE: last night watching tv, picture cut off (black
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
