Delta 40-690 20-in Variable Speed Scroll Saw Logo
p
pliquori Posted on Jan 09, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a fuse on delta 20 inch variable speed scroll saw
Cant get fuse out
gregmk
Level 2:
Sergeant:
  • Expert 204 Answers
  • Posted on Jan 09, 2015
gregmk
Expert
Level 2:
Sergeant:
Answers
204
Questions
0
Helped
86434
Points
896
There is a delta web site that gives you a down load manual if you don't already have one.
it shows you where the fuse is located on page 10 - fig. 10.
here is a link to the page
After inserting bottom of blade it pulls to right when tightened
You may think that the deck on your machine is level, but it may be off. Check with a level and make sure. I believe this is your problem. GOO LUCK FRIEND.
Cannot replace motor on scroll saw
I never tried changing motor but have you contacted a Technical Rep already? or looked on the manual?
Where are the brushes in the dewalt 788 20" scroll saw? Mine keeps blowing fuses & I think the brushes need cleaned but don't know how to get to them
Blowing fuses is not caused by brushes unless there is a huge spark show going on and if that is the case your armature will be trashed as well - the electronic module in that saw is notorious for failure and that is where I would start
Cannot access fuse in a dewalt scroll saw dw788
Hi, if the fuse has never been changed it may just be stiff, also when
it says push it may be that your are not pushing in the right direction
some have to slide and push at the same time, however, assumingyou have tried this, then it would make sense to revert to the screwdriver
method , but gently and at the opposit end from the word push...T.C.
Top Delta Saws Experts
Jay Finke
Jay Finke
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Delta Saw Expert? Answer questions, earn points and help others
