Pilot light will not stay lit
Cleaned out the inside of furnace and replaced thermal coupelar.
  • 63 Answers
Will it stay lit for a while? If so light the pilot light, Turn on the blower fan, and watch the pilot light. Look for any air that's blowing the pilot light around. if the pilot lite is moving around then you could have a bad heat exchanger. If so you should get a carbonmonixide detector and have your furnace inspected for this. One thing to check also is make sure the thermocouple is at least 1/4 inch into the flame.
Posted on Jan 28, 2008
Why won't my Robertshaw gas furnace pilot light stay lit..Do I need a therm couplen or What.
if gas line to pilot generator clean and sill wont stay lit need new pilot generator
Jan 10, 2016 | Robertshaw 720-007 universal gas valve for...
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
My heat won't come on.
Newer furnaces do not have a pilot light. If yours does, you will have to relight it. Find the gas valve inside the furnace and follow the lighting directions. Generally, you turn the valve to the pilot position, press a button and hold it while you light the pilot. Hold it for about a minute and then release. If the pilot stays lit, then you can go ahead and set the thermostat to call for heat. If it does not stay lit, or the furnace still will not light, I think you need to call a repairmen or someone with knowledge of how to troubleshoot the problem.
Mar 21, 2014 | Heating & Cooling
Not firing up
Try cleaning the thermocoulpe. If its dirty and sooty no enough heat gets to it and the pilot won't stay on. Also make sure its aime inside the hottest part of the flame. The small blue tip of the flame.
Mar 01, 2014 | Slant-Fin Corp Heating & Cooling
Pilot on my gas furnace won't stay lit
Try cleaning the thermocouple tip if you can see ashes or any buildup on it. If you know the wind isn't blowing it out (had mine blow out from high winds before) then I would change the thermocouple before anything else.
Dec 09, 2013 | Heating & Cooling
When I tried to light my furnace, the electrical wires from the thermostat don't spark all the time, therefore my furnace won't stay lighted. What can I do to fix this?
Is this an older furnace where you have a pilot light? Are you saying the pilot light will not stay lit? If thats the case then likely you need a new thermal couple. That is what the pilot light keeps hot while it stays lit. It is a safety device that is there so your furnace will not come on if there is no pilot light present. Very common. Hardware store item. Need Furnace's make and model #'s.
If this is an electronically controlled furnace, you will need a service call.
Jan 13, 2012 | Heating & Cooling
Pilot won't stay lit on furnace
Is that pilot automatic? If so then a quick easy fix for this is to located the sensor and replace it or clean it up with sand paper. After ignition the control is looking for verification of ignition from that sensor. How to videos
Sep 30, 2011 | Heating & Cooling
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
I have a williams wall furnace model 5009622,and the pilot will not stay lit ,i cleaned the thermacouple,still no luck,i also then replaced thermal couple still wont stay lit,any other ideas thanx ,i was...
Assuming the pilot is clean and sharp. Before replacing the valve, clean any spade connections, those going up to the spill switch in particular. Clean and tighten all 4 connections. Good luck.
Jan 11, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I can't get the pilot light on my furnace to stay lit.
take out the pilot assembly. there is a small burner and an orfice. the orfice does get clogged if it has not been operated for awhile. you can clean it out with a small sewing needle. if the pilot wont light or stay lit, replace the thermocouple.
Dec 06, 2009 | Heating & Cooling
Heating & Cooling Logo
250 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
