Question about Olympus EVOLT E-500 Digital Camera
Exposure compensation problems
Whenever i use the exposure compensation feature of the e500, it seems to lock in even when i turn it off (the compensation factor). i end up with underexposed pictures. i have to use the camera reset function to be able to meter correctly. resetting is fine except that it means i lose all my custom settings and have to go thru the whole process again.
    Problem Solver:
  • 8 Answers
The exposure compensation stays where you leave it unless you do a full reset or a custom reset, and except when you're using scene modes. But you don't need to do a reset to cancel out an exposure compensation -- simply use the exposure compensation button to adjust the compensation back to 0.0EV.
Posted on Jan 29, 2008
How do I fix over exposed pictures outdoors
Check and make sure you don't have the exposure compensation settings set higher than 0. There is a manual override feature that lets you apply over/under exposure compensation to every photo rather than manually setting it for each shot. Sometimes, this feature can get accidentally changed. If that's not the issue try to reset the camera back to its default settings through the menu feature.
Aug 07, 2014 | Canon EOS Rebel XSi Digital Camera
Over exposed photos
Your exposure compensation might not be set correctly. Just behind and to the right of the on/off switch you will see a small button with a "+/-" symbol. That is the exposure compensation switch. When you press it, you will see a number displayed on the LCD. If the number is positive, that is your problem. Positive numbers increase exposure and negative numbers decrease exposure. Set the compensation to 0.0 by turning the rear thumbwheel while depressing the exposure compensation button.
Jan 09, 2014 | Nikon D90 Digital Camera with 18-105mm...
Whenever I take close up photos with a white cloth background it comes out blue, even in natural light. I use the auto feature as it works well for my jewellery it's just the colour balance I need
The exposure meter in your camera is underexposing due to the white background. Try adding up to two stops of positive exposure compensation. What you are seeing as blue is in fact grey - it may be an idea to calibrate your monitor as well.
Aug 10, 2017 | Canon PowerShot G11 Digital Camera
Exposure locked on manual
Is that 10 seconds? 1/10 second? f/10?
What happens when you turn the command dial? What happens when you hold down the exposure compensation button and turn the command dial?
Jan 30, 2013 | Fuji FinePix S9500 Zoom Digital Camera
My D90's multiple exposure won't turn off !!
Have you tried going into the menu and finding "reset"?
Mar 01, 2010 | Nikon D90 Digital Camera with 18-105mm...
The built in speedlight on my D 70S is not synching. Seems like the flash goes off before the shutter opens.My pictues all comes out dark no matter what I try. Can you help me?
I fixed this same problem with my D70s today, after twelve months of getting dark pictures despite the flash firing. It started syncing properly after I performed the following, though I'm not sure why as I was just mucking around.
- Set Program to P. - Push button to activate built-in flash. - Push, and keep depressed same button, which will put you in Flash Exposure Compensation mode. - My Flash Exposure Compensation was on +0.3 so I set it to 0.0 by turning the front wheel. Seemed to fix it.
Sep 23, 2009 | Nikon D70s Digital Camera
400D manual mode
You are exposure compensation in manual mode. If you want the shots lighter, either open up the aperture or slow the shutter. The exposure compensation feature is to override the automatic settings determined by the camera in the auto-exposure modes.
Dec 05, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Exposure/ISO compensation
usually around 15 to 20 rolls of 36 exposure film. the iso compensation will either lighten or darken your prints. a good feature if you don't want to change depth of field. ( f-stop )
Aug 07, 2006 | Pentax SF1n 35mm SLR Camera
DS Exposure Question
I haven't found any underexposure problems with my DS. The only "underexposure-thing" I found is that when it's sun reflections within the image (from water, cars with metallic paint and other highly reflective surfaces) the camera will underexpose to avoid blowing out the highlights. In complex lighting situations with many dark and bright areas, it will expose to retain texture in the shadows but still without burning out the highlights. The only image-processingt that I sometimes needs to do, is to lift up the midtones. The darker tones and the bright tones are in most caes exposed just the way I would do it myself if I was a camera, but the midtones can be off. Now, this is not a fault in the camera - it's an effect of the limited dynamic range that digital has in comparision with film. Lighten up the midtones without affecting exposure of dark and bright areas, is image processing and has nothing to do with exposure settings.
Sep 08, 2005 | Pentax *ist DS Digital Camera
Exposure and flash problems
I assume your camera is the Olympus D520. This camera gives you very little control of the flash. The only thing available to you is the ability to change the Exposure compensation. I would experiment with raising the exposure compensation adjustment a few steps. This may or may not help. What you describe is quite common. The flash distance on small cameras is usually only about 10 to 12 feet and past that distance, it quickly falls into blackness. Some cameras have Slow Synchronizing which lets the lens stay open a bit longer past the flash. This adds light to the background. You might check the manual and see if your camera has that feature.
Sep 06, 2005 | Olympus Camedia D-520 Zoom Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
129 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
