Question about Bose Lifestyle 38 System
No sound just installed a new system. completed setup and installation, but speakers have no sound.
  • Tom5314 Oct 09, 2008
    I have the same problem. I did what's your recommendation and still no change. The base subwoffer has no green power light no mater I turn the power switch on or off, it's just like "dead", and yes I did plug in the different outlet. Could it be the cable?
  • 51 Answers
If the speaker system is not playing from any source eg radio,cd , hard drive etc.... check base module has power and system cable inserted correctly. also check the connection is firm at rear of media centre. once all has been checked turn power to both base module and media centre off for 1 minute . if this doesn't work post and we have more things to try
Posted on Nov 16, 2007
  • Jacob Argent Nov 16, 2007
    post to find more solutions to thius problem
I have a new PC with Vista installed. BA 745 do not work.
check to make sure you have the speaker icon in the bottom right hand corner. If you do, see if you can move the sound bar up and down. This will verify that you definitely have the right sound drivers installed and they got installed properly.
Make sure you have the speakers connected properly. Here is a setup poster to show you how. Follow this just to be sure
Once you verify this and the sound still doesn't work then it could be a problem with the speakers or the sound card or sound chipset (if you have integrated sound on the motherboard).
To verify whether its the sound card or sound chipset on the motherboard or whether it could be the speakers. Put the speakers on another machine that you know has the sound drivers installed and turn up the sound bard in the operating system thru the speaker icon. If you get sound then its a problem with your other computer. If you still dont' get sound then the sound speaker system is bad and would need to be replaced.
Jan 14, 2010 | Boston Acoustics BA745 Computer Speakers
I have recently had to install a new hard drive. now my speakers say ''no audio device detected'' I have tried reinstalling the drivers that came woth the comuter - says ''not installed'' after I go...
If you are able to identify your Motherboard model, your problem is 80% solved. Find the model and check for the driver in the manufacturer;s website
Nov 15, 2009 | Microsoft Windows XP Home Edition
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
I have Integrated sound card but there is no sound or vol. icon control appear on my widows and on device manager their is an yellow exlamination mark
hi im josh in cebu phils.may i help you? Friend try to use these solutions of mine it will help you for sure Problem: Your New Sound Card Doesn't Work—You Don't Get Any Sound Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
Okay, now that the easy stuff is out of the way, let's turn to something more difficult. The most likely cause of no sound is some sort of conflict. One by one, change your card's DMA, IRQ, and port settings. (This might entail resetting some jumpers on the card itself, as well as making some software-based changes.)
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work.
Problem: Your New Sound Card Crashes Your System If you've just installed your sound card, you might not have the card properly installed. Check your installation (is the card properly seated and connected?) and then reboot your system.
If this doesn't fix it, you have something wrong in your setup. Check your software setup to make sure you have the same DMA, IRQ, and port assignments as selected on your sound card itself (usually via DIP switches or jumpers). If the settings are correct, you probably have a conflict of some kind. You should methodically change the DMA, IRQ, and port assignments in Windows so that they don't conflict with the assignments for other devices on your system. thats all friend good luck hope i helped you.
Mar 04, 2009 | Fujitsu Siemens ESPRIMO P2500 PC Desktop
Installed a new Sound Card which does not work.
i think it will only run 1 card at a time so you will need to disable or uninstall the reaktek?
Mar 01, 2009 | Computers & Internet
I had to reinstall my windows xp and my speakers are plugged in but no sound comes from them and my computer cant find them
If you are trying to re-install windows, you have to re-install the sound drivers also once the setup is complete.
You cannot hear any sound untill you install proper sound drivers.
Jan 17, 2009 | HP JBL Platinum Computer Speakers
Sound card
Remove cover and find a slot which is made for the card you have to install. Plug in the slot plush so you can place a screw to hold card, (be sure the power cord isn't plugged in while working inside)Once installed in computer, plug in and have drivers disc ready in rom.When new hardware is found, send to disc, if doesn't find new hardware run the setup on drivers disc. Good luck Jimmyriggs
Jun 09, 2008 | Ozaki DT-500 3-Piece Speaker System...
No sound coming from new hp monitor through windows vista
Alright, I got the answer for ya, first, go into your control panel. Click on Sounds and Audio Devices. Listed in this window should be the name of your sound card. Under that, should be Device Volume, and at the bottom, should be the Speaker Settings, click into Advanced, next to speaker volume. It should show you a diagram of a monitor with the amount of speakers it has selected shown next to it. Where it says Speaker Setup, click and then scroll down until you see 3 settings labeled Monitor Stereo, Monitor Stand Stereo, and Monitor Mounted Stereo. Whatever one enables the sound will be the one you want to stick with.
Feb 25, 2008 | Gateway Essential 500 PC Desktop
Both rear speakers on my z540 system play only the left side rear
Hmmm, this sounds like either a driver issue, or a card/compatibility issue. you might try reverting to old drivers(last resort), making shure you have 4.1 enabled in sound control pannel(do this first), triple checking connections/connectors on both the speakers and the card(remember, you only have 5 speakers, not 8) and if you have the headphone-type phone plug for your speakers, you might try making shure that they are compatible with the jacks on your card, although, I would have to know more about your setup to be completely shure.
Dec 26, 2007 | Logitech Z-540 Speaker
Bose Lifestyle 38 System Logo
199 people viewed this question
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
