Question about Symphonic SC319C 19 in. TV/VCR Combo
TV Problem Hello, I have a Symphonic TV/VCR combo. The video won't eject, and the command on the TV says "Eject T", it usually just says "Eject". Also, it turns on for about 5-10 seconds and then shuts off automatically. I'd appreciate your help please thank you!
  • Gandalf25 Jun 14, 2008
    I have a 13' Symponic tv/vcr same problem
  • Anonymous Jul 25, 2008
    Video tape won't eject and says eject t-also turns off after abot 10 sconds
I have this problem too i dont know how to fix it either
Posted on Mar 15, 2008
TV won't release my DVD when I press open/close
you need to reset your tv and this shoud solve the problem if not let me no
May 14, 2014 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Vcr stuck on eject and poiwers off right away
Chances are that something has become damaged inside the unit and as the unit can't get out the tape, powers off to stop any further damage. The only solution will be to remove the video by entering the unit. As this is a TV unit care should be taken of the high voltages connected with the TV part. And should only be undertaken by someone with experiance.
Feb 09, 2013 | Symphonic SC-3813 13-Inch TV/VCR Combo
I also have a 19" Symphonic tv vcr combo which
The problem is with the vcr section, it is stuck in eject mode thinking there is a tape. This a mechanical problem that might be repairable. The tv and vcr share some of the same circuits, you can try resetting the tray in the out position as if it fully ejected the tape. Now if this does not work it means you have a gear timing problem or bad sensor.
Dec 23, 2010 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic tv vcr combo will not eject tape
You need a new VCR belt it located on right side of the vcr tray take your finger and start rotate the belt clockwise, it should release the tape. or the motor is going bad.
Apr 25, 2009 | Symphonic SC319C 19 in. TV/VCR Combo
Dvd & vcr DV2140
Nov 01, 2008 | GoVideo Go Video DVD/VCR Combo
Tape wont eject
Veri8fy that the belt on the side of the VCR mechanism is intact. If it is, then check that the motor works, by appying 12 volts to it,with the belt disconnected. If the motor works, it might be that your mode switch needs cleaning, and that takes some fancy unsoldering and soldering.
Sep 06, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
Tv cuts off
being it was older and a left over gift....we trashed it and saved my husband's blood pressure.
Aug 06, 2008 | Symphonic Televison & Video
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
Symphonic SC319C 19 in. TV/VCR Combo Logo
357 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
