Received call earlier today that I ignored now there is a low volume high pitched ring constantly.
SOURCE: my Sony ericsson k800i is not ringing in full volume
I had exactly the same problem and came to a conclusion.
When you are playing in your music player at the same time it's playing use the volume keys on the top of the phone.
I hope this helps
SOURCE: my ringing volume is very low i have tried
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
SOURCE: NO VOLUME WHEN RINGING, THOUGH
not the problems no volume is there there is any pin code for use in indian do give the answer
