SOURCE: Garmin Etrex Vista Date problem
Thanks to a hint from a user on another web forum, I have found a fix, at least for now.
Specifically, a normal "master rest" on the eTrex Vista is accomplished by holding down the "Page" button and "Enter" (i.e. the click stick) while powering up. You are prompted that a full reset will occur, and after confirming, the machine is reset. However, in my case, this achieved a full reset, but did not fix the date problem.
However, the undocumented "super master reset" on the eTrex Vista is achieved by simultaneously holding down the "Page, "Enter" and "Find" buttons while powering up. You have to hold all buttons in for about 5 to 7 seconds, and you DON'T get the warning message, but when the machine finally restarts, it is fully reset. After acquiring a satellite fix (took several minutes) - lo and behold - my time AND date both seem to be correct!
Oddly, neither Garmin tech support nor the local reseller seemed to know about this method of REALLY resetting the machine - I will pass on the information to them, for future reference.
The link which documents the "super master reset" procedure is here: http://www.gpsinformation.org/dale/secret.htm#reset
Hope this might also help other eTrex Vista owners who are experiencing the same date problem.
SOURCE: Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
SOURCE: Garmin Etrex Legend Cx - no signal
Have you tried upgrading the unit's software. Go to Garmin.com and download the latest software for your unit. This will sometimes fix satellite reception problems.
SOURCE: garmin etrex screen too dim to read
I have an older Garmin 12XL and suddenly the screen turned very dark. I tried replacing the batteries and let the GPS rest for a week so the internal lithium battery could re-charge. But that did not work. I just got an email from a friend who had the same problem... it turned out that his unit had changed the screen contrast setting all by its' self.
This may not be the cause of your problem but it's worth trying... go into your "Settings" menu and reset the contrast and see if that cures the problem. Good luck.
SOURCE: Geocaching with Garmin Etrex Legend CX
The preloaded maps are VERY generic, mostly major highways. They are not useful for geocaching.
The good news is that you can download free topo maps created by a very generous Canadian soul, Dale Atkin. The maps are free but donations are accepted. He is also working on US topo maps. I've used Ibycus and Garmin topo maps and prefer the Ibycus version.
If this solves your situation, please come back and rate our answer. Thankyou.
