Question about Panasonic PT-47WX49 47" Rear Projection Television
Burn in on sides of screen
Hello there, my problem is white burn in on the sides of the screen, I could use your advice on how to fix
Re: burn in on sides of screen
Burn will go away by itself, I had the same problem.
Posted on Feb 06, 2008
  • 1,694 Answers
Only one way = replace all three CRT's ! ........................T.
Posted on Jan 30, 2008
0 characters
3 Points
I bought a 52" Polaroid for like 50$ and the
the white circles are called halos caused by technically a burn-in u either ignore or change the screens particularly the one on the inside for a new one......the halos have made a burn-in on the screen its like taking a spot light and pointing it to a surface for long the light will eventually image its circular image on the surface like a discolouration hence the snow like white balls as u call them....another suspect the optical dome glass maybe dirty u got to open the box screen chamber and use a soft cloth to clean it
Jul 17, 2013 | Projection Televisions
Panasonic model TH-42PW4 manufactured 2001. TV cuts out and goes into stand-by. Sometimes only bottom half of display works. Can hit on button and it will come back on, not dead yet. Dennis
Well Dennis I do not want to discourage you , But it is a problem with the power module or the the board
just for kicks have you seen if the remote Power Button is sticking or the TV
I know this sounds crazy but if the remote is sticking it will send an IR signal
to shut off/stand by
Thank You
Sep 11, 2008 | Projection Televisions
Tiny white spot in screen
hello could be screen burn
Jul 31, 2009 | Projection Televisions
Red circle and yellow tint in our white
If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
Good Luck
Do not forget to Rate!!
Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
Sounds like you have burn in. A condition from watching a channel a lot that has a non-moving picture, like ESPNHD usually does. It's kind of the same condition old console style video games would burn the score into the screen.
Mar 14, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue on the left and right sides of my rca scenium, 65 inch hi def rear projection tv
Well what may have happened is a bad thing, See if you can find some way of displaying a totaly white pix, and have this full size filling the entire screen. If the side bars are still there this means the CRT's are burned and this is a perminate thing, The fix would be to change the CRT's mabe just the green and the red but they still run about $285.00 each. This was cause by having the set run in a format that DOES NOT fill the entire screen
Jan 12, 2008 | RCA Scenium D40W20 40" Rear Projection...
Image retention
most manufactures say not to have a still image on the screen for more than 15% of your viewing time. to fix this you will have to replace the optical assy. i did come across a sony projection where the burn in was actually on the screens themselves. the only thing you can try is to put an all white video pattern on your tv for at least 48 hrs.
Oct 06, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Toshiba 42h81
Hello, one of possible solutions is to replace capacitors (10uF/50V) on HYPER (PD0246) module. Please ask the tech to check/replace them. If you need more info please advice.
Apr 27, 2007 | Toshiba 42H81 42" Rear Projection...
Screen Burn In ?
Nope Not unless you replace the tubes with the burn in them You have to take off ther front screen and look into the lens while tvs on and you will see what tube is burned worse. Sorry!!! but I have heard of folks equilizing the burned tubes by taking a solid color one at a time (red,green and blue) and keeping on only one color on for 4 to 6 hours one at a time and them all on at a time for a solid white and have seen some pretty good results.. Good Luck
Apr 19, 2006 | Zenith E44W46LCD 44" Rear Projection...
Burn In
i dont think there is much you can do about this which wont cost a fortune
Mar 26, 2006 | Sony Grand WEGA KDP-65WS550 65" Rear...
Panasonic PT-47WX49 47" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Projection Televisions Experts
Jaime Hernandez
Josh Whitehead
Josh Whitehead
Are you a Panasonic Projection Television Expert? Answer questions, earn points and help others
