Hello I have LG model lsc27931 there's no power to the ice maker or water dispenser and the light in the freezer is out I changed the bulb and still no power everything else seems to work the display reading are good I have ice in the bin but no power I flip the on and off switch need help please
It sounds like you have a short in it somewhere, if it's under warranty then have it repaired, if not then take a volt meter and check to see where it's dropping power at.
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
I Have a Solution for this Problem,Contact live on line Now ttech
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
