My ps3 have error d5027 and freeze alot wend l go to faceboo
That error basically means your network connection to the PS3 network servers is unstable. Given the time of year and the number of kids that have snow days and are at home, and parents staying home working across the internet, the most likely cause is simple network congestion. You should notice this issue go away early morning when fewer people are online, and get worse as the day progresses. In some cases, you can set up a VPN or Virtual Private Network connection that can help. If you want to try that, go to this link http://community.us.playstation.com/t5/PlayStation-Home-Support/Using-Virtual-Private-Network-VPN-To-Defeat-Network-Error-D50027/td-p/44868077 for instructions on setting it up.
SOURCE: ps 3 freezes when ps button is pressed
PS3 is one of the most amazing gaming device but like other competitor gaming
devices (Xbox and Wii) It also has some problems like Freezing up. You may
check out the informative Article at ezinearticles Remedy
for PS3 Freezing up
SOURCE: ps 3 games freeze
unit maybe internally dirty not letting it cool properly get canned compressed air and bloww out throughly!!! :)
SOURCE: my ps3 was working and then it says
Probably not enough speed for it to work, PS3 needs a good connection, try to use 1 device at a time and see if anything turns up.
SOURCE: On ps3 home error code D5027 any ideas why?
That code means that the servers are temporarily down for maintenance. See the following link:
http://go.avforums.com/?id=223X354&url=http%3A%2F%2Fcommunity.eu.playstation.com%2Fplaystationeu%2Fboard%2Fmessage%3Fboard.id%3Db_EN_PS3_Home%26thread.id%3D45183
