Question about Motorola Mobility RAZR V3m Cellular Phone
Front display not working
I dropeed my phone and now the out side display is not working - any advise on this?
    Brigadier General:
  • 7,752 Answers
Have the lcd replaced , take it to a mobile service center and have them replace it for you.
Posted on Feb 08, 2008
Droped in water screen dosn't work
You must be very lucky if the phone works well again. But to make an attempt remove the covers and wash well with petrol the printed circuit board both sides making sure that the plastics or display does not come into contact. This is purely to remove all trapped moisture withinthe pin configurations. Now use a dryer( hair dryer) very mildly so as to take off trapped water inthe through holes of the double sided board.
Repeat the job after few hours ,use a soldering iron if there are signs of smoky lead ( traces of battery voltage in electrolysis)
If there is fumes coming on when soldering iron is touched on spots repeat till you are sure of a total dry PCB.
Assemble back to check.
Sep 17, 2010 | Motorola Mobility Rival A455 Cell Phone
I droped it and the screen wont turn on
Since you said the phone drop from you, it is possible that the screws that attach the screen of your phone is not tight anymore.
I suggest you get a torx6 screw driver, power off the phone, remove the battery and turn the the phone over.
Carefully remove the front cover of your phone that leads you to your phone screen.
Use the torx6 screw driver to tighten all the screws of your screen very well to the panel of of your phone.
Recouple your phone back, put the battery and power on, the screen should display.
But if the screen did not display, it means the flex on your phone is bad and will need to be replaced.,
So change the flex if tightening of the screen did not work, so change the flex on your phone and your phone will display.
Take care.
May 08, 2010 | Sony Ericsson T715 Cell Phone
Nokia n96
trying to wash complete your phone with pcb cleaner
Jan 16, 2010 | Nokia N96 Cell Phone
My nokia display screen looks black on one side and colored dots
your display has broken.lcd are made of glass,its easy damage when phone is droped.must change display in service
Dec 07, 2009 | Nokia 6300 Cell Phone
Its one of the most common problem in Samsung SGH-A707.It is mainly due to one reason i,e. your cell got wet.....!!!
But you can try following steps to get rid of it:
  1. Takeout the battery of your phone.
  2. Leave your cell in air for a day or two without attaching battery and battery cover to it.
  3. Put the battery back,it should work.If still problem exists, then I'll recommend you to buy a new battery for your cell........and before you put that new battery in your cell,leave your cell in air for another two days with the same procedure.
Nov 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
Samsung SGH-a707 solid red screen and says download! PLEASE HELP!
Sir you probably have droped your phone in water...........thats the reason it displays DOWNLOAD on front display..........takeout the battery leave your phone in free air for a day or two to (Remember you dont have put the cover back)...........after two days put the batter back in phone your phone should work well now.........if problem still exists change the battery........
Mar 30, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Nokia 6085 has a blue screen
I have the same problem with my Nokia 6085 phone. was working fine and then it started glitching after a month the glitching display went blue. after 3 days it started working again but I had to power it off and on again and when I did that my display was gone again. I cant text. I know my phone and where everything is so I tryed to send a text but it will not work but I can make and get calls.
Mar 30, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Front cover display
If you go into setting and then go into what I think is called display settings then you may be able to scroll down and then it may say "Brightness"
You should be able to change it like that.
If its not under display settings then its deffintly under somthing else in settings!
I owuld tell you the EXACT way to do it. But my phone got droped into water so its hard to tell you becasue the buttons wont work..
So therefore I have to try remember the instructions of my heart. I hope I helped you with your problem, and I hope it wasn't a bit to late :)
Jan 24, 2008 | Motorola Mobility RAZR V3
Front display
its simple chanhge display streep or chsnge display(lcd)
Aug 07, 2007 | Samsung SCH-a870 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
32 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
