Question about RCA F19207BC TV
Antenna hookup broke off
The metal connector where you hook up the antenna wire broke. I can get sound and a little picture but not clear. It is either snow or fuzz. I was wondering if it was possible to reconnect it or buy another antenna for the tv. we have directv so i am guessing that we need a wire antenna hook up.
    Scholar:
  • 87 Answers
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Posted on Nov 12, 2007
On my CPTOH-0603, i'm getting great picture but no sound. Just have antenna hookup directly. Would I need a receiver for the sound to come on? Or maybe not hooking it right.
the antenna is getting a good picture and as sound and picture are bound from transmission I am thinking that there is a problem in the sound board/ section of the tv
Mar 24, 2017 | Televison & Video
Do i need an antenna to recieve FM radio?
Yes. Stereo receivers typically have either screw terminals or a coax connector on the back for an FM antenna. You can use a TV antenna for this since FM radio is in the middle of the old TV VHF band. However, if the station you want is nearby, you can pick it up with a piece of telephone hookup wire (solid 28 gauge copper) connected to the antenna screw terminal (strip the insulation off the end of the wire that is connected to the terminal, but leave the rest of the insulation on). If you have only a coax connector, slip the end of the wire into the center terminal on the connector. The wire ideally should be about 30" long, but you may get by with less.
For more distant stations, you may want a long-range TV antenna.
Mar 22, 2015 | Audio Players & Recorders
Tundra antenna removal
You will have to un-install the entire antenna system from the inside.
remove the panel carefully adjacent to the antenna system
undo the bolts and clamps that hold the system in place
you can try and install the new antenna piece without disconnecting the transfer wire that goes back to the radio. But usually you will need to get and install a new system.
just to keep you going in the mean time you could just use a old wire coat hanger "classic" just bend the hook straight and shove it in, you have your sounds back.
all the best
Feb 02, 2014 | 2010 Toyota Tundra CrewMax
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Apr 20, 2012 | Pioneer Audio Players & Recorders
The antenna on my ICF-SW7600gr broke off. I want to solder on a new wire lead. should i only connect to the top solder point, or to all three where the old antenna plate rested?
There is only one antenna connection. That is the wire or pin in the middle of the coax connector where the old antenna was connected. Hook that to your new antenna, the other connectors are usually at ground potential and won't help a bit. Often a piece of wire the same length as the old antenna will work fine. Stretch it in the vertical position as was the old antenna.
Zashiban
Jun 23, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Scanner antenna causing static
Sounds like a bad, loose or dirty connection.
it's possible that there may be a broken soldered joint on the antenna connector.
Open up( power off first) and resolder the joints as they can breakdown over time(dry joint).
Aug 14, 2009 | Electronics - Others
What type of indoor antenna work best with this unit?cobytv/tf-tv
A simple pair of rabbit ears (standard dipole antenna) should do the trick. You will have to set the source input to NTSC/ATSC and connect the antenna to either the analog or digital F- connector inputs if you use a RF splitter you can use one anatenna for both inputs. In any event try this first.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 06, 2009 | Coby Televison & Video
HD Hookup on Dish Network 2nd Location
In order for you to receive HD broadcasting you must have a HD-TV, otherwise you wont get the picture in HD. Also I should point out that you need to make sure that the signal itself is being broadcast in HD.
Apr 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
RCA F19207BC TV Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
