I have tried to change the volume letter, and tried to change the volume name.. i have tried to use various recovery tools, all of which detect no media. I have attempted to format the drive with multiple tools, all of which discover no media. of course all windows disk management tool are of no use.
You can try this tool
Flash Drive Repair
SOURCE: usb flash drive 2 gb
Hi ...
When that happen try going into the device manager area >>> start >>>
control panel >>>system >>> hardware tab >>> device manager , now notice
your usb controllers area , its mostly likely open and if so ?
See if you notice a little yellow exclamation mark http://en.wikipedia.org/wiki/Exclamation_mark by it , if so , right click on it
and select delete , then highlight your computer name http://en.wikipedia.org/wiki/Naming_scheme on the very top of the
devise manager , select " Action " and then select " scan for hardware
changes , at this point your compute should now notice your usb devise , by
the way make sure when you are performing this that your usb devise is plug
in , See if that helps.
Else refer to this website http://www.uwe-sieber.de/usbtrouble_e.html
This site every issue related to USB device.
I am sure this will surely fix your problem.
Thanx for using fixya,
Bye.
SOURCE: I have an 8 GB
in that case it may be a hardware problem.send it for warranty.
once again check the disk management it may not be allocated.
SOURCE: My flash is unreachable and unformatable
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply hope this helps you
