SOURCE: 2007 Chevy Uplander Rear Overhead A/C Vents Won't Work
Have you checked the Aux switch near the bottom of the center control console.
There should be a knob with: Aux, Off, 1, 2, 3. This is the switch for the rear AC blower.
If the driver wants to control the rear AC, use the 1, 2, 3 settings.
If you put it on Aux, Than the rear AC is controlled by the passenger in the back seat using the extra controls located on the Overhead DVD player. (The front AC must be on the rear to work)
SOURCE: Have 44k on a 2008 chevy uplander. Front left
I have a 2008 as well.. with 39K and the front right needed replaced.
it was covered under the 100K warranty
SOURCE: rear wiper on chevy uplander does not work. fuses
i have a 2006 chevy uplander and i need to change the low beam headlamp how do i do it, also about a month after we had got the van the rear wiper stopped working i haven't checked the fuse yet, but is this a common problem for the uplander, and also the abs light stays on what should i do for that problem, and also when we drive it and then shut it off it does not want to turn on right away.
SOURCE: I'm getting trouble code p1174
i have an 2007 chevy uplander flexfuel i keep getting p1174 also i have replaced the the o2 sensors and the light keeps coming on
i belive it has something to do with the fuel injection system
SOURCE: I HAVE A CHEVY UPLANDER AND THE REAR WIPER WILL
The rear wiper on the uplander is a common BOSCH unit and is very prone to one very small but very easy ( and CHEAP to fix ) problem. The shaft that goes through the glass on the rear hatch needs to have new grease.Thats it......If you think you need a new wiper motor try this.......take off your old wiper motor and remove the star drive screws that hold this thing together.Now pull this thing appart. Dont be afaid to do this remember you think that you are going to buy a new one anyway right. Inside you will see the electric motor with a worm gear thar turns a big yellow(or white) plastic wheel.sitting on top of that is a funky metal linkage that is connected to the BOTTOM of the shaft.On the TOP end of the shaft you will need to remove the small plastic ring and under that the small rubber o-ring. Now you need to pull the shaft and the linkage out of the unit. They should just pull out with no effort BUT you will find that they are stuck because all the grease has gone hard around the shaft stopping it from moving.Use a little penitrating oil around the shaft and work at it and it will come out. Now use a little break cleaner to clean the shaft and linkage ,apply new grease and put the thing back together again. PROBLEM SOLVED......try it .....trust me you dont need a new motor :-) If you really want to be lazy you dont even have to take the car apart just unbolt the rear wiper arm and remove thearm fron the car then clean the end of the shaft andunder all that dirt you will see the small plastic ring and under that the small o-ring .....remove both of these.now spray some penitrating oil down the shaft.give it a little timeand spray some more.try the rear wiper,if your lucky it will start to turn.put it all back together again.
