291,299. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: CODE FOR TCL TV UNIVERSAL REMOTE CONTOL-CHUNGHOP RM -133E
If you don't have a code you can do these steps to get your universal remote working with pretty much any tv:
1.) Turn your TV on. Then on your remote press the set button, it's the small gray button above the green button that says TV.
2.) Press the TV button. There should be a red light to the right of the SET button. This means that your remote is ready for the TV code.
3.) To find the TV code, press the + or - on your remote. This is located above the orange buttons. Once the volume on your TV goes up or down, stop pressing the + or - button.
4.) Then press the SET button again to set that code for your TV.
If the above steps do not work, keep trying. It will work! ;)
SOURCE: i have a chunghop universal remote, RM-133E and i
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
SOURCE: chunghop remote control RM-133E LG
Hello
Codes for LG tv with Chunchop RM-133E universal remote control are:
024/040/098/043/040/259/260/261
OK.
SOURCE: may I please have the code for kevin RM-133E code
Here are the following codes that you can try:
