Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Hp flat panel monitor looses picture
Turns on than looses picture
  • Anonymous Feb 21, 2008
    Screen goes black. It is 3 years old. I turn it off and wait twenty seconds and turn it on. it comes on ok again. Very irratic..
    Now today is OK..
    Any ideas????
    It is used about average of five hours a day six days a week,
If you are having monitor problems with the picture make sure the backlight to your LCD is working properly. best way to figure that out is check the screen if the picture is still there just black. Then replace the backlight sheet.
Posted on Mar 19, 2008
  • 42 Answers
Having the same exact problem with the same moniter it is stamped july 2004 i found a site i can link you to.i have torn mine apart and will let you know what i find.i see there was a class action lawsuit on the same moniter but 17 inches.it looks like the 15's have the same problem .....i will post a link later today
Posted on Feb 25, 2008
Here
Here
and Here
I've tried all the aforementioned fixes, and my conclusion is... when your monitor's dead it's dead. Go to NewEgg and and get a new one.
Posted on Nov 26, 2007
Hp pavilion f70 monitor turns white. when i turn it off and back on with the monitor power buttom the video returns but goes off again after a few munutes.
Verify that it's the monitor and not the computer by hooking another monitor to the computer and observing the results. If it's your Hp f70 that is the problem, then something in it is going out, like the inverter or perhaps a loose connection. If you don't want to open the monitor and have a look-see for yourself you can always take it to a shop to have it checked out.
Mar 13, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
No power when u plug in an turn on HP vs15 15 in. Flat Panel LCD Monitor.can u tell me how to open it up so i can check the switch
You need thin flat blade screw driver to crack open the case, it is almost the same as VS19, more likely to havebad caps with bulging tops, see pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20VS19D/
Mar 10, 2010 | HP vs15 15"LCD Flat Panel Monitor
HP laptop monitor for dv7-1170us does not work
It sounds like your flat vga cable has pulled loose inside the panel. Just take the lid apart on your screen assembly and press that flat ribbon cable back in and tape it in place.
Mar 09, 2010 | HP Computers & Internet
MY monitor flashes, goes black then comes back on. This happens once in a whyle.
well this might be because the power cord of the monitor is loose contact so check it. if it is ok then check the power options settings in the control panel- performances and maintenance- power options- power schemes you will find turn off monitor option select the required option from drop down list and apply the settings.
good luck
Jan 05, 2010 | HP Pavilion F50 17" Flat Panel LCD Monitor
My hp pavilion f70 flat panel lcd monitor comes on and works fine with a beautiful picture...for about 1/3 of a second. then it goes blank. any ideas how i can fix this or what might be wrong?
Hi:
The symptoms you describe, pretty much diagnose a failed High Voltage power supply board problem in the monitor. This is usually cost prohibitive to repair, as LCD monitor prices have dropped a bit, so your monitor is beyond economical repair.
Nov 30, 2009 | HP Pavilion F70 17" Flat Panel LCD Monitor
HP f1905 monitor problem. The monitor does not
There are 3 low ESR Electrolytic capacitors in the power supply that fail. They are 1000uF 25V and can be replaced with RS Components opart number 315-0619
Sep 27, 2009 | HP f1905 19" Flat Panel LCD Monitor
Auto adjustment comes on every 5 seconds
Sometimes that can be caused by a loose or bad video cable causing the monitor to re-adjust for the video signal. You could try resetting the monitor by unplugging it for a few hours and re-plugging it again too. Also check with HP and see if they have any warranty, extended warranty, repair notice, free repair/ replacement.
Jun 21, 2008 | HP f1905 19" Flat Panel LCD Monitor
No picture
Try to reverse the cable....use the end connected to the computer at the monitor and the monitor end to the computer. If tapping the monitor doesn't do anything and tapping the cable at the computer does the same faults then I would have it checked or just replace that cable.. Good luck.
Dec 02, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
