Question about GE Profile Spectra JBP95 Electric Kitchen Range
Model JBP79 FFFcode
After a brief power outage, the power returned, but the range flashed a code of FFF. We flipped the circuit breaker and left it off for a minute or more but that did not fix it. We tried all the clear/reset buttons, also no fix. The range top still works, but the oven and other push button controls don't do anything.
  • Anonymous Mar 19, 2014
    Is there a reset button
JBP 79-Right Burner with inner and outter burners. Inner burner with not ger hot. Can inner burner be changed?
Posted on Aug 21, 2009
  • 473 Answers
FFF Control Error, Failed EEPROM Replace Control
Unfortunately when you get this code the oven control will need to be replaced.
Posted on Nov 12, 2007
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
After a power outage, what is causing my Frigidaire stove to beep and display an F11 code?
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
Apr 23, 2015 | Frigidaire Kitchen Ranges
The cooling fan for the stove top stays on due to a burner showing HE but not on or hot
Hello Chris Lowman, thanks for your inquiry!
I understand that your Frigidaire range, FGES3065KFC, is flashing the error code "HE". However, it appears "HE" is an invalid error code. We should try resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue and you continue to receive an "HE" I would recommend reaching out to a professional. He or she could come out and perform an accurate diagnosis on your range to assure the repair is completed properly. I hope this information is helpful. -Matt
Nov 04, 2014 | Frigidaire Kitchen Ranges
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
While playing my unit we had a brief power outage. When the power supply returned the " PROTECT PUSH POWER " message comes on. Is there a button that I can push to reset my unit-LBT-X50 .
Your sound system may have a circuit breaker.
Check the rear of the sound system for a circuit breaker that has popped out, Then push it back in.
It may be labelled.
  • circuit breaker
  • protect push power
Otherwise unplug your unit from the wall and wait 5min before you plug it back in, then press the power button on the front of your system and your remote control.
I hope this helps
Jul 13, 2011 | Sony LBT-LX50 CD Shelf System
E1-F1 error,
depending who made it, i would say its probably a whirlpool ....
that suks this is common after power outages..
1. Frst disconnect the power for at least 30 seconds. at the unit or breaker
2. Plug power back in and wait for couple minutes.
3. If code shows up again, replace the control board (also the electronic control board or ERC or clock.
note-usually boards are expensive couple hundred dollars so decide if u wanna get a new range .. k take care hope this helped
Jan 28, 2010 | Kenmore 96532 / 96534 / 96539 Electric...
Unit shuts down upon temporary loss of power
Its time to shake a local rep and ask for an exchange on that controller. If they want to sale us on customer service then make them eliminate that as a possibility an exchange it for free.
Jul 18, 2009 | Heating & Cooling
Oven shows stop on display and cant be used
I don't have a solution but a thought. Sometimes the main circuit board can be corrupted during a power surge or outage. You may need to have the circuit board re-set by a professional tech or replace it. Can you try going to the breaker box/pannel and flipping the breaker off for about 30min. to let the circuit board re-set. If that doesn't work then see if someone else has any suggestions or call a tech.
Apr 26, 2009 | Kitchen Ranges
GE Stove clock shows FFF and oven will not work
GE Error Code: FFF
Condition: Door motor safety circuit
Fix: Repair Electronic Range Control (ERC)
Usually, failure happens after power surge.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | GE JSP26 Electric Kitchen Range
GE Profile Spectra JBP95 Electric Kitchen Range Logo
779 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
