Question about HP G40 Power Supply (09502531) Power Supply
Hp d220mt when i turn the computer on i get 2 short beeps, a pause, and then another short beep. i've tried the ram and its in there firm. this computer also has a built in video card and never had a problem before. i may of pressed a cmos button while i was installing a new 512 ram stick.. i doubt i'll be able to do a rompaq because of it not showing any video..
  • krissweep Nov 13, 2007
    it didn't work, the post beep code is 2 short beeps a pause and another beep. like i said i pressed a stupid cmos button on my motherboard and it may have wiped bios. its a ami motherboard and i'm getting pretty frustrated at it... i tried a few different sticks which work in other computers but for this one computer it isn't. it takes a pc2700 ram which i am sure i have. i just took out everything in my machine and even regreased my cpu. i'm stumped!!
    well i tried another monitor and it worked fine. my girlfriend just bought a 20" acer gaming monitor and its very touchy with video cards i guess and my old monitor worked fine. thanks for the help and glad to know there are people around to help if needed. cya
    President:
  • 3,130 Answers
Take the ram back out of the computer that you just installed and see if you have the same problem. If you do, a board or plug must have came loose when you were inside the unit. If the problem clears up, the ram you are trying to use is bad or not compatible with your computer. All ram is not alike. Good Luck
Posted on Nov 12, 2007
What do the beeps codes i am getting mean? 1 short followed by 1 long.
Beep codes don't cause or signify damage, they are just telling you something is wrong. In your case, I would say the RAM is incorrectly seated or in the wrong slots.
2 beeps Memory (RAM) not detected
Remove the RAM and press it HARD until it locks in place. Do a visual check that the indent is against the mounting.
Computer POST and beep codeswww.computerhope.com/beep.htmHelp and support with troubleshooting computer beep codes and other POST related issues.
PC Hell: BIOS Error Beep Codeswww.pchell.com/hardware/beepcodes.shtmlPhoenix BIOS Beep Codes These audio codes are a little more detailed then the AMI codes. This BIOS emits three sets of beeps. For example, 1 -pause- 3 -pause 3 -pause.
beep codes Definition from PC Magazine Encyclopediawww.pcmag.com > Tips > EncyclopediaPC Magazine Tech Encyclopedia Index - Definitions on common technical and computer related terms.
How to Figure Out Why Your PC is Beeping (Beep Codes)pcsupport.about.com > Troubleshooting Guides > Symptoms2015-10-07 · Video embedded · How To Troubleshoot Beep Codes. Is Your Computer Beeping? Here's What to Do. By Tim Fisher. PC Support Expert Share Pin Tweet ...
Jan 23, 2016 | Computers & Internet
Beeps:1 long 8 short pause 2 short pause 1 short
The first couple of beeps ( 1 long 8 short) points to graphics problems. Check the graphics card is seated firmly. If this fails, remove the graphics card and plug the monitor into the onboard graphics slot
If you have only the onboard graphics slot, try seeing if a graphics card, plugged into the motherboard ( may be agp or pcie fitting) solves the problem
The second pair of beeps ( 2 and 1) sounds like ram issues, if they are still there after you solve the graphics problem, try removing one ram module at a time and if it boots ok with that module removed, it is likely to be a faulty stick of ram
May 13, 2011 | Computers & Internet
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
My compaq persario sr1000 power is on the fan is on. but it beeps with a short beep and keep on. beeps pause and beeps again all with the power on but no picture on the moniter
The beeping you are hearing is a beep code. Since their is no visual image a specific series of beeps is played and repeated to help pinpoint the problem. The beep you are describing, and it is hard for me to know for sure without hearing it is, sounds like a problem with your RAM.
First, try reseating the RAM. If you have multiple sticks of RAM remove them and reinsert them. To remove the RAM, push the tabs on both ends down and remove the stick of RAM.
Reinstall them by pushing the RAM firmly into the slot until the tabs click in place.
Try booting up again. If the same beep happens try removing all of the RAM except for 1 stick (if you have multiple sticks).
If you do not have multiple sticks, you may want purchase or borrow a stick of RAM to test your machine with to determine if your RAM is faulty.
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 01, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
How can i fix my IBM ThinkPad T22 2647. it produce 3 simultaniuos beep sounds lcd is black out.
This is a list of ThinkPad Beep codes.
It appears you have a memory or motherboard problem, most likely a RAM problem. Try reseating the RAM modules, if this doesn't work, then remove the RAM and take them to your friendly computer repair shop to get them to test the RAM modules for you. If the RAM is faulty them replace.
Beep symptoms
Symptom or error
Service part or action, in sequence
One beep and a blank, unreadable, or flashing LCD.
  1. Reseat the LCD connector
  2. LCD assembly
  3. External CRT
  4. System board
One long and two short beeps, and a blank or unreadable LCD.
  1. System board
  2. LCD assembly
  3. DIMM
Two short beeps with error codes.
POST error. See Numeric error codes for more help.
Two short beeps and a blank screen.
  1. System board
  2. DIMM
Three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
One short beep, pause, three short beeps, pause, three more short beeps, and one short beep.
  1. DIMM
  2. System board
Aug 06, 2010 | IBM ThinkPad T22 2647 Notebook
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
When starting up the computer, I get 5 short beeps then continous
These beeps seem to show that your system did not detect any RAM (memory) modules connected to it. Please check.
  1. Open the CPU case (turn the PC off first)
  2. Remove the RAMs from the slot.
  3. Turn ON your computer without the RAMs installed. Then observe if it gives the same beeps. If it is the same, then the RAMs might fail to register.
  4. Try to plug in carefully the RAMs in place. If you have 2 RAM modules, try to test 1 RAM at a time to see if the combination of the 2 mess up your system.
Feb 13, 2010 | Computers & Internet
Beaping Sounds When turning PC on
These beeps sound exactly like that of the RAM. If you are not too skeptical about going inside your PC, you can simply remove the RAM and reseat it back firmly. Sometimes this happens that the memory loses good connectivity and would just need a reseat.
Thanks,
Lolita
Mar 02, 2009 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
Computers & Internet Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
