Our Rinnai ran perfectly last season but this season just last week it started turning off after it had been on for about 5mins. We have found it does it less if we have it on real low but need to fix it as low heating just doesn't cut it in -2degree nights with little ones in the house. Anyone please help so we can keep these children warm?
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however...
(More)
I have a Rinnai Energysaver 1001ft it has the outlet at the back for the heater ducts. I, however would like to have the heated air to blow from the front vents. How do I achieve this? My email add. is nwidmer@bigpond.net.au thank you Nick Widmer
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I...
(More)
I would like our Rinnia 1001ft to blow heat out the front grill and not the rear duct how do I achieve this
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when...
(More)
rinnai energysaver 1000ft I havent used it before - we just bought this house with it instaled. when I turn it on the fan goes for a minute or so, the ignition fires and the red light turns on, then the whole thing shuts down . any help?
