Question about Cadet Manufacturing 67508 Coil / Ribbon Compact Heater
Not a cadet but a King
I hope you can still help me. My King wall heater has air moving but no heat and I have a red-orange light showing. I checked the breaker and all is ok there. No funny smell or noises. Just no heat. Thank you very much. Cindy.
  • 625 Answers
Shut off the breaker, then, remove the front grill. look for a device about the size of a nickel. could be fastened to the upper case. this is called a klixon overload. there are numbers stamped into the side of it. one of these are either temperature or an amperage value. get a replacement from an electrical supply house. it is probably blown. it is in series with the element. its purpose is to open [then reset] when an increase in current is evident. it is a bi-metal device - two dissimilar metals that bend at different rates when current is applied to it and opens a set of contacts.
Posted on Nov 16, 2007
I have a cadet wall heater, the orange light comes on, i have to shut it off and turn it back on. It is blowing heat.
There is a little sensor called a 'flame sensor' that is inserted into the actual flame. Its only job is to complete a grounding circuit on the control board actually through the gas flame... By the description of your problem, it sounds like it either has oxidation on its surface OR the physical connections at the flame sensor itself or where it plugs into the control board have just enough oxidation to imhibit the signal from the flame sensor.
I would suggest calling the service center to have a tech look at it.
Dec 22, 2014 | Cadet Manufacturing Heating & Cooling
How do you know the temperature heater is running at when set on light orange 1st or 2nd square
The only way to tell is to use a thermometer as the outlet heat is based upon the surounding air temperature.
Aug 02, 2014 | Rinnai EnergySaver ES38 Gas Fired Direct...
Fujitsu ASU18RLQ heater/air conditioner with 2 green and 7 red flashing error lights
Here is a link to the error codes.
http://www.fullyairconditioned.com.au/images/uploaded/files/fujitsu%20fault%20code%2
0split%20system.pdf
Hope you find an answer there.
Feb 15, 2013 | Fujitsu ASU18RLQ Single Zone Wall Ductless...
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
Cadet C151 heater not producing warm air.
take your tstat off jump out the wires red green white together. if it works like that then your thermostat is bad. if it doesnt then it is in the unit.
Mar 24, 2010 | Cadet Manufacturing Com-Pak Plus C151...
My cadet c202 heater is running the fan is blowing cold air but no heat, is it the thermostat or heating elements or both???or ?????
I work in a motel and replace these heaters quite often, Cadet C202, a 240v 2000 watt wall heater. Most of the time when they blow cold air it's because the heating element is broken. First turn off the circuit breaker, then remove the heater from the wall. If you take out three screws, slide the top cover off, bend the two little tabs and take out the heating element, you can examine it and usually you will find a place where it is broken, it's like a big spring. Replacement elements can be ordered from online stores such as reliableparts.com Be very careful, 240 VAC is very dangerous! <!-- from fixya rte -->
Dec 31, 2009 | Cadet Manufacturing 67507 Heater
There was an electrical smell when the heat was on
Could be ,to be certain take it out the wall and check
Mar 07, 2018 | Cadet Manufacturing 67508 Coil / Ribbon...
Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Sep 11, 2008 | Heating & Cooling
Cadet Manufacturing 67508 Coil / Ribbon Compact Heater Logo
520 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
