Re: What do the buttons on top do specifically. I do not...
Here is the manual for it this should get you the info you need to know. hope it helps you. this is the link for the users manual. Mach Eclipse 180 8GB User Manual
To turn on your Arctic Pro portable air conditioner manually, follow these steps:
Make sure the unit is properly installed according to the instructions in the owner's manual.
Plug the power cord into an outlet and turn on the power switch.
Press the "Power" button on the control panel or remote control to turn on the unit.
Set the desired temperature using the "Up" and "Down" buttons on the control panel or remote control.
Press the "Mode" button to select the desired cooling mode (e.g., "Cool," "Dry," or "Fan").
Press the "Fan" button to select the desired fan speed (e.g., "Low," "Medium," or "High").
Press the "Swing" button to activate the oscillating function, if desired.
Press the "Sleep" button to activate the sleep mode, if desired.
Press the "Timer" button to set a timer for the unit to turn off or on at a specific time.
Press the "On/Off" button to turn off the unit when you are finished using it.
Note: The specific buttons and functions may vary depending on your model of Arctic Pro portable air conditioner. Refer to the owner's manual for more information.
Language set-up mode
In order to enter the language set-up mode proceed
as follows:
1) Make sure the audio unit is switched off.
2) Press and hold buttons 1 and 4 simultaneously.
3) Press the power button and the radio will switch on.
4) Release all the buttons and the display will show
LANGUAGE.
5) Press the << or >> button and the language
setting display will change as follows:
ENGLISH ? FRENCH ? GERMAN ? ITALIAN
?DUTCH?SPANISH?POLISH?ENGLISH
Once the language has been set, switch off and
switch on again the audio unit by pressing the power
button.
You can remove your comment manually..
By following these steps.
1. At the right top of your comment you will find a small pencil icon or cross symbol when you move your mouse.
2. Select small pencil icon to edit the comment that you post.
or
3. Click on cross symbol to remove the comment.
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
the fuel lines on this vehicle are held on by a clip that is just inside the fuel line itself .it is circuler and made of plastic. just past that is a raised ridge that the clip holds onto(you cant see the ridge) if you want to remove the clip their is a special tool that you can buy ( normally come in a set of different sizes) they are fairley cheap . if you dont want to buy the tool you might be able remove the clip by using a screwdriver to pry the clip as evenly as posible all the way around the line( havent tried it myself as i have the disconnect tools .but have been told it can be done. be carefull not to damage the clip
Screen size selection sometimes called aspect
ratio--Check each menu/page selection to gain
understanding of each function/feature.Consult owner/operator manual.If not available,WWW--
Akai Owners manual.
