ZEEPAD New 7 Inch Android 2.2 Tablet Pc Wifi 720pvideo Supports External 3g Silver Color Tablet 256mb Ram 2gb Hard Drive Silver Size 7 Inch Screen Logo
M
Melinda L Krestel Posted on Jan 05, 2015
Why won't the zeepad hold a charge. - ZEEPAD New 7 Inch Android 2.2 Tablet Pc Wifi 720pvideo Supports External 3g Silver Color Tablet 256mb Ram 2gb Hard Drive Silver Size 7 Inch Screen
How do I turn on zeepad
Press and hold the power button until the display lights up with a symbol of some kind. If that does not work it probably needs charging or a replacement battery or servicing.
1helpful
Will my zeepad charge threw my pc. charge light has come on but zeepad has not
You cannot use a computer USB port to charge a tablet, unlike charging a smartphone. You will have to use the supplied charger. If you really want to use the USB port to charge your Zeepad, you will need to custom-built a cable using any extra USB cable you can spare. Just change the connector at the remote end of the cable to one that suits your Zeepad's 5V DC IN socket. You are forwarned the connector is not easy to find.
Why won't my zeepad 9xn charge? When I plug it in the indicater light flashes on the off quickly! I just to it not even a week ago
You must first charge your Zeepad for a minimum of 9 hours prior to using it for the first time. Though it may show that it is fully charged after 4 or 5, you must leave it on the charger. When you go to turn it on, you must hold the power button for at least 3 seconds.
I bought 4 ZEEPAD 7DRK Rock tablets for my grand kids for Christmas and 2 of them will not even turn on. The 3rd one worked for 3 days and it also will no longer turn on. I've tried charging them...
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
7" Zeepad 7.0 Allwinnwer is fully charged but wont work
I am problem with my tablet.. it wont go on home screen at all,, stay on andriod blue guy.. can i replace new one or something to make it work
My zeepad screen has spiderwebed and won't register touch anylonger. is it fixable
Most places even if you have a warranty wont fix a broken screen mine has the same problem so i bought a digitized touch screen replacement on Amazon.
My zeepad won't boot up
I'm having the same problem I've tried everything and nothing's working please help
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
