It sounds like there might be an issue with the power button on your Rinnai RC-329ac heater. Based on your description, it appears that the power button is not functioning properly and the heater can only be turned on by using the "good night" button.
There could be a few reasons for this. One possibility is that the power button is physically damaged or malfunctioning and needs to be replaced. Another possibility is that there's a problem with the control board, which is responsible for managing the heater's functions.
To troubleshoot this issue, I would recommend checking the following:
- Check the power button to make sure it's not physically damaged or jammed.
- Check the control board for any visible damage or malfunction.
- Make sure the wiring connections are secure and not loose.
If you are not comfortable working on these issues, it's best to call for professional help as it may require a technician with experience in Rinnai RC-329ac to properly diagnose and fix the problem.
