SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
SOURCE: sound no picture
Most likely the TV has a power supply related problem. The most common problem are the power supply for the screen itself. Most manufactures call it a Backlight Inverter Board. Something you may want to look at for your problem. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
SOURCE: Philips 42PFL3603 tv sound but no picture.
Return it to waranty repair or replacement ur video backlight inverter board is dying going to be dead,than u have no video(picture at all)might just sound.
SOURCE: I have a 2 year old Samsung 50 Plasma HD TV with
Please check the power supply, Z-SUSTAIN board, Y-SUSTAIN board for blown fuses, bad caps first. You can download the PLASMA TV training manual to learn about PLASMA TV by the link below.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
