2005 Dodge Magnum Logo
Posted on Jul 07, 2009
Dash Warning - BAS Light
BAS warning light came on during normal operation. Stopped vehicle at next intersection and restarted vehicle..light went off. Car has 94,000 miles. What could this be?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1376
Points
Why my bas light come on?
My Brake light on the dash was on and intermittent. I changed the brake fluid sensor and it went out. I drove it stopped someplace shut off the ignition after restarting it the brake light is on again
Check the precise function of the dashboard warning light in the vehicle handbook - light often has a shared function. Brake fluid level sensors are very reliable and rarely fail so it is likely the fault is elsewhere, perhaps in the wiring, connectors, etc.
As your car is probably fully digitised, it is possible the light came on and it logged a fault code that might need erasing with a suitable scanner before normality is restored.
2answers
1991 previa dashboard warning lights wont come on when trying to start van
Hello, it's very likely that some fuses blew during the battery disconnect/cleaning. There are some fuses under the cover on the center of the dash above the radio, there is another fuse box under the hood, this is where the 100A alternator fuse is, check it and if it's blown replace it. Check all the other fuses using a 12 volt test light with the key on.
2answers
I have an 06 Dodge Magnum. ESP/BAS light
Whenever this warning or any other stays on in the dash it id indicating that the systems control module has detected a fault, it then disables the system as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
I have a 2004 grand prix 3800 engine non turbo. Engine was eratic at cruise with rpms at 1200-2000. rpms would lope 2-300 rpms. I Changed air and fuel filter, and cleaned the throttle body. also checked...
i had a problem with all my lights coming on in my 2006 explore took it to dealer to find out that the battery was dying replaced it and they went away
3helpful
2answers
1helpful
Air Bag Light, Brake Light, & ABS Light came on in the dashboard.
Check and see if your alternator is charging
Low voltage will cause those lights to come on, as the computer is shutting down.
To check your alternator you will need a volt meter... WITH the engine running you should have about 14 volts coming out. IF NOT you need to replace the Alternator!
Problem with my cruise control and ABS light on 03 Explorer
Anti-Lock Control —Vehicles Built After 03/2002 The 3-channel anti-lock brake system consists of the following components:
  • front wheel speed sensors
  • front wheel speed sensor rings
  • hydraulic control unit (HCU)
  • Anti-lock brake control module (ECU)
  • rear wheel speed sensor
  • rear wheel speed sensor rings
  • yellow anti-lock brake warning indicator
The 4-channel anti-lock brake system with traction control and stability assist system consists of the following components:
  • active brake booster with integral solenoid
  • brake booster release switch
  • stability assist module (ECU)
  • stability assist event indicator
  • lateral accelerometer
  • longitudinal accelerometer (4x4)
  • rear wheel speed sensors
  • steering wheel position sensor
  • yaw rate sensor
  • brake pressure transducer
  • traction control switch
I suspect the abs issue is causing the speed control not to work if it happened at the same time the cruise control stopped working. When the yellow ABS light comes on, it means the ABS is dactivated. You may have a faulty accelerometer which senses acceleration and yaw (side to side lean). I have not seen a bad one but you said it is sensitive to acceleration.
I would unplug it and see what happens. The connector should have a small tab to depress so you can pull the connector out.
Here is where it is:
Accelerometer Removal and Installation
  1. NOTE: The accelerometer is located under the center, rear passenger seat carpet. (I think you have to remove seat for access).
    Cut the carpeting along the perforations.
  1. Disconnect the electrical connector.
  1. Remove the nuts and remove the accelerometer.
Have dealer hook up tester and pull fault codes if you can't find an easy solution.
Some background info
  • A malfunction in the anti-lock brake system will cause the anti-lock brake control module to shut off or inhibit the system. However, normal power-assisted braking remains.
  • Malfunctions are indicated by the yellow ABS warning indicator in the instrument cluster.
  • The anti-lock brake system is self-monitoring. When the ignition switch is turned to the RUN position, the anti-lock brake control module will carry out a preliminary self-check on the anti-lock electrical system indicated by a three-second illumination of the yellow ABS warning indicator in the instrument cluster.
  • During vehicle operation, including normal and anti-lock braking, the anti-lock brake control module monitors all electrical anti-lock functions and some hydraulic operations.
  • Each time the vehicle is driven, as soon as vehicle speed reaches approximately 20 km/h (12mph), the anti-lock brake control module turns on the pump motor for approximately one-half second. At this time, a mechanical noise may be heard. This is a normal function of the self-check by the anti-lock brake control module.
  • Pedal pulsation coupled with noise while braking on loose gravel, bumps, wet or snowy roads is normal and indicates correct functioning of the anti-lock brake system.
  • Warning Lamp Indicator
    The anti-lock brake system (ABS) uses the yellow ABS warning indicator to alert the driver of a malfunctions in the ABS.
    The yellow ABS warning indicator will come on to warn the driver that the ABS has been turned off due to a symptom that exists in the ABS. Normal power assist braking remains but wheels can lock during a panic stop while the yellow ABS warning indicator is illuminated.
    Please report back, I am curious if that is what it is. Good luck
    2helpful
    BAS / ESC warning light
    there is a software update for this vehicle to cure this problem...contact your dealer
    2answers
    Anti lock brakes
    depending on the system if it is 2 channel or 4 channel one of the sensors that are located on the backing plate located behind calipers is eithier faulty or dirty you can try brake cleaner these sensors use a small magnet pickup device to sense when the wheel "locks up"
    Top Dodge Experts
    ZJ Limited
    ZJ Limited
    Thomas Perkins
    Thomas Perkins
    Arnie Burke
    Arnie Burke
    Are you a Dodge Expert? Answer questions, earn points and help others
