Beats me but this seems to be the answer
What Does the Lightning Bolt Symbol Mean on Dodge Charger Instrument Panel...
SOURCE: bas light dodge magnum
Same thing happened to my 2005 dodge magnum. Took it to the shop, we thought it was a computer issue. Flashed the computer and it didn't help. It ended up being the thermostat and some other parts. The shop had to remove the whole front grille to replace a part that went straight through the top of the engine. The part is plastic and had cracked and was slowly spewing coolant all over the engine. The car was basically overheating but so little that it was not evident at first. Once they replaced all of that the lights stopped coming on. Very frustrating to say the least.
SOURCE: I have an 06 Dodge Magnum. ESP/BAS light
Whenever this warning or any other stays on in the dash it id indicating that the systems control module has detected a fault, it then disables the system as long as the light is on. You must now have the dealer hook up a special electronic diagnostic tool and "scan" the system for the fault code that is stored for the problem(s)
