Question about Cannon Office Equipment & Supplies
How do i re align the head on aMX432 cannon
I re filled the black cartridge at costco and now it says the head needs to be aligned??? how ? i have since replaced the ink w/cannon factory cartridge,will this go away?what do i do now????
    Scholar:
    New Friend:
  • 98 Answers
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizhow do i re align the head on aMX432 cannon - horizontal_black.gif horizontal_black.gif
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
    Even if the patterns with the least amount of streaks are clicked in the preview window, thow do i re align the head on aMX432 cannon - print_pattern2.gifutomatically entered in the associated boxes.
    • If ihow do i re align the head on aMX432 cannon - vertical.giflt to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if thhow do i re align the head on aMX432 cannon - print_pattern3.gife least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/Ehow do i re align the head on aMX432 cannon - horizontal_cyan.gif.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Posted on Jan 05, 2015
SOURCE:
I filled my hp 61 cartridges myself.I am having problems getting the ink to flow right,with the black cartridge
When filling cartridges yourself (i.e. DIY kits) you need to ensure that a proper vacuum prime occurs...often this is tricky if the internal foam is not properly 'wetted'. I suggest you take your HP61 ink cartridges to either Costco (most locations) or any Fry's Electronic Stores for ink refilling (typically ~40-70% cost savings vs. new cartridge cost)...the refill operators use a commercial grade ink refilling machine that preps, evacuates, cleans and then fills the cartridge automatically....followed by an electrical nozzle/jetting test. Anything goes wrong (at home) and you'll likely get a refund.
To find the nearest refill Costco store location and/or Costco pricing information, you can find this information at http://www.costcoinkjetrefill.com
For additional ink refill support information or advanced HP printer diagnosis/testing procedures for your printer model, please visit Inkjet411:
http://www.inkjet411.com
Aug 14, 2013 | HP DeskJet 1055 All-in-One Printer
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My cannon pixma mp500 won't print in black
Hello
Please replace or re-fill the black cartridge.
Good Luck
Jan 17, 2011 | Canon Pixma MP500 All-In-One InkJet...
I have a Kodak printer ESP5250. I have replaced the black ink cartridge, done a printer head alignment, and cleaned the printer heads. When I print a black and white printout I only get the outline, the...
Did you replaced the cartridge because of this issue or because it was depleted?
Since Kodak cartridges have the Print head attached to each cartridge it may be that the cartridge it malfunctioning.
To Test use a lightly damped paper towel and put the cartridge or print head where the ink comes out in top of the paper towel if ink start flowinf to the paper towel then the cartridge is fine, otherwise try to exchange that cartridge for a new one.
Oct 30, 2010 | Kodak ESP 5 Printer
Cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 19, 2009 | Canon PIXMA iP1600 Printer
Alignment failed refer to device documentation hp L7780
You need to remove the black/yellow printhead and dab it on a damp paper towel until you see a solid line of black ink on the towel when you press it. It won't pass the alignment until all colors work properly.
Nov 19, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
No black ink
Check ink levels. Control panel > printers > right click on printer and choose properties. Look for a tab that says something like color management or maybe just color. Should be an indicator of how low the ink is. If you are lucky to have one of the more translucent ink well cartridges, you might be able to remove and hold cartridge to a light to see how much is in there. If very low or empty, you'll need to replace it.
If ink is in there, reinsert the cartridge and peform a nozzle test or head cleaning. Also do a head alignment. All of these things should be options in the printer properties.
Still no black? Maybe a problem with print head and will require servicing or replacing.
Bret
www.1-2-1computerservices.com
Oct 06, 2009 | Cannon i70 Printer
Can't find where the ink cartridges are on the cannon mp830 to replace
THE INK CARTRIDGES :
This multifunction printer is compatible with all of the following ink cartridges. Here is a list of these cartridges and how they you can get them:
PGI-5 Pigment Black
CLI-8Bk Black
CLI-8C Cyan
CLI-8M Magenta
CLI-8Y Yellow
All of the ink cartridges are easy to install and/or replace; all you have to do is keep the printer ON, then open the cover it will come in the position and then unlock the cartridge which allows you to remove and replace the cartridge.
These cartridges cost any where between $10 and $15 each. But if you want a good deal, I would suggest purchasing your ink supplies from Costco Wholesale as they provide good prices on packages.
Jul 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Top Cannon Office Equipment & Supplies Experts
Clive
Clive
Inky Fingers
Inky Fingers
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
